sidecars-and-cocktails Posted July 31, 2022 Share Posted July 31, 2022 Hi guys, my K1200 has a lock of some sort, so I can't walk the bike around. The front is fine but the rear wheel only rotates maybe 8cm before locking in either direction. Does anyone know what's up with that? Thanks Link to comment
dirtrider Posted July 31, 2022 Share Posted July 31, 2022 2 hours ago, sidecars-and-cocktails said: Hi guys, my K1200 has a lock of some sort, so I can't walk the bike around. The front is fine but the rear wheel only rotates maybe 8cm before locking in either direction. Does anyone know what's up with that? Thanks Morning sidecars-and-cocktails Is the transmission still in a gear? (not in neutral?) Otherwise we need WAY more information to help you. Like when was the last time it was movable? (Last time it was ridden) Is the neutral light on with the key on? Can engine be started with clutch held in? Link to comment
sidecars-and-cocktails Posted July 31, 2022 Author Share Posted July 31, 2022 Bro, thanks a lot, you were right. I figured out where the clutch was and put it in neutral.. she's fine now. Link to comment
