HYoungblood Posted May 29, 2006 Share Posted May 29, 2006 Anyone having problems with their cruise control on their 1200RT. Sometimes mine will not engage the red light will flicker then will go out. Then it won’t work at all unless I shut the bike down for a while. Also when mine is working if I turn on the high beam it will shut down the cruse. Link to comment
bimmers Posted May 29, 2006 Share Posted May 29, 2006 Never had a problem with it. Don't know if I have had it on with hibeam though. Take it to the dealer and they reprogram it for you. Link to comment
ADulay Posted May 30, 2006 Share Posted May 30, 2006 No problem with mine so far but I don't believe I've tried the Hi/Low beam switch with it on but I'll try next time out, just for grins. AD Link to comment
oregon Posted May 30, 2006 Share Posted May 30, 2006 Haven't played with mine a whole lot but noticed if the brake lever was adjusted to be closest to the grip (1?), the cruise control would occasionally cancel as if I'd touched the brake. Link to comment
Rusty1945 Posted May 30, 2006 Share Posted May 30, 2006 Anyone having problems with their cruise control on their 1200RT. Sometimes mine will not engage the red light will flicker then will go out. Then it won’t work at all unless I shut the bike down for a while. Also when mine is working if I turn on the high beam it will shut down the cruse. I run my high beam all the time and have used the cruise with no problems. Looks like a trip to the dealer for you Link to comment
Fergie Posted May 30, 2006 Share Posted May 30, 2006 Sounds like you might have a ground problem. Cruise is using the high beam circut for a ground and when you turn high beam on the ground goes away. Seen this problem in lights before. Find out where all the grounds are and check them. Link to comment
Redbrick Posted May 30, 2006 Share Posted May 30, 2006 No problems with mine and it works great but I miss the ol' "Flip-a-Lever" on the K75..... Phil.........Redbrick Link to comment
HYoungblood Posted May 31, 2006 Author Share Posted May 31, 2006 Contacted my dealer today. He seams to think there may be a problem with the cruise control switch. So we made an appointment for next Friday. Hope to have good news later. Link to comment
Iron Al Posted May 31, 2006 Share Posted May 31, 2006 Mine is working fine (knock on wood ) and I use if often. Link to comment
Dolph Posted June 1, 2006 Share Posted June 1, 2006 I had a problem with the cruise control on my 05 RT when new. Turned out that there was excess tension on the wire connecter block under the rear seat causing an intermittant fault. Loosened the tension on the wires and pushed them into the block firmly, have had no further problem in 12,000 miles Link to comment
ADulay Posted June 1, 2006 Share Posted June 1, 2006 Sounds like you might have a ground problem. Cruise is using the high beam circut for a ground and when you turn high beam on the ground goes away. Seen this problem in lights before. Find out where all the grounds are and check them. Is that true? Cruise uses the hi beam circuit for the ground? Methinks that would be a good thing to know! Thanks. AD Link to comment
Fergie Posted June 1, 2006 Share Posted June 1, 2006 No the cruise does not use the high beam for a ground. However if the cruise has lost its ground it will look for a ground. That's why you need to make sure the cruise circut has a good ground. The most common cause of electrical problems is a fautly ground. Link to comment
ADulay Posted June 1, 2006 Share Posted June 1, 2006 Fergie, Thanks for the clarification. AD Link to comment
cjmkerns Posted June 6, 2006 Share Posted June 6, 2006 My cruise wouldn't stay on after 2 days of heavy rain riding. Acted like a loose switch and may have been due to the silt like film the road water had left all ove the bike. When I got home I put a good shot of WD-40 (Water Displacement formula # 40) into the left switch housing on either side of the set/res switch (catch the outflow on a rag). All returned to normal. YMMV. Regards, Carl Link to comment
HYoungblood Posted June 12, 2006 Author Share Posted June 12, 2006 Took the bike to the dealer on Friday and they replaced the cruise control switch. After a weekend of riding (and in a heavy rain)the cruse is working fine. Link to comment
keithb Posted June 12, 2006 Share Posted June 12, 2006 No problems with mine and I absolutely love this accessory. One of my favorites of the bike. Goodbye sore wrist. Link to comment
oregon Posted June 12, 2006 Share Posted June 12, 2006 My R12RT's cruise control went away this weekend. First wouldn't stay set then didn't light up the "Set" at all. Still have a red light on the handlebar switch. Time for a trip to my dealer (who's really first class) to see what part died. I'll update the list when it's figured out. Everything else (knock wood) is working fine with 1k miles so not a big deal. Really do love this bike. -- Larry Link to comment
steve539 Posted June 15, 2006 Share Posted June 15, 2006 Mine did Exactly the same thing at the start of a 3500 mile trip. It is at the dealer now. Let us know what is done to yours and we can all compare notes. I don't like the thought of my cruise going out if it gets wet in a heavy rain. Link to comment
oregon Posted June 18, 2006 Share Posted June 18, 2006 My R12RT's cruise control went away this weekend. First wouldn't stay set then didn't light up the "Set" at all. Still have a red light on the handlebar switch. An update on my inoperative cruise control -- stayed dead until the mile-long trip from work to the dealer. Tested it again on the way and it worked fine. Still working fine. No significant weather change. We'll see how it lasts. Link to comment
cranezilla Posted June 19, 2006 Share Posted June 19, 2006 My cruise started doing the same thing this morning. Engae cruise, turn high beams on or off, cruise dissengages, adjust windshield height, cruise dissengages. Gotta be the switch, will make a appointment for the brake recall and have the cruise checked at the same time. Link to comment
Albert Posted June 20, 2006 Share Posted June 20, 2006 Just finished a trip to Maine and back from Pittsburgh which included extensive use of the cruise (and some extensive rain too) . Mine worked great and was a godsend for the right hand/wrist. I did notice that on around 3 occasions the cruise did a quick off/on then returned to normal. It felt like his little electronic hand needed a break for a second or two. Link to comment
steve539 Posted June 27, 2006 Share Posted June 27, 2006 I just got the DX on my cruise control failure from BMW of Daytona. The cruise switch at the handlebar. It was difficult to find due to the lack of an error code on the computer check. I hope to have it done by this weekend. Link to comment
