jacko Posted May 28, 2006 Share Posted May 28, 2006 Hi Guys I have a leak from the diff last time that happened the crown wheel bearing was stuffed. But this time the oil looks clean and no noise or play in the wheel ,could I be lucky and its only a seal. Thanks Jacko Link to comment
Eckhard Grohe Posted May 28, 2006 Share Posted May 28, 2006 Where be the leak exactly???? Link to comment
Stan Walker Posted May 28, 2006 Share Posted May 28, 2006 could I be lucky and its only a seal. You could be. I was. I replaced just the seal in March of this year. After 69,000 miles it was starting to weep. I had the new 17 ball crown wheel bearing sitting there waiting but didn't use it as the old bearing was still in good condition. It's now 1700 miles later and everything checks fine. Stan Link to comment
jacko Posted May 29, 2006 Author Share Posted May 29, 2006 The leak is the main crown wheel seal. I have just finished replacing it ,everything looked ok . Didnt dismantle the diff this time , Will go for a ride and check for leaks thanks Jacko Link to comment
