Rotor Posted June 14 Share Posted June 14 Any of you have experience with this battery or something you can recommend that gave you good performance? https://www.autozone.com/miscellaneous-non-automotive/power-sport-battery/p/duralast-agm-ready-to-ride-power-sport-battery-etx14l-220-cca/273066_0_0?cmpid=LIA:US:EN:AD:NL:1000000:BAC:8366688869&gclid=EAIaIQobChMIwbLb_POt-AIVioXICh1QGAZCEAQYDiABEgLQm_D_BwE&gclsrc=aw.ds Want an AGM I can purchase locally. Link to comment
beemer chuck Posted June 15 Share Posted June 15 Those are good batteries, made by DEKA in Pennsylvania. have used them in several bikes. My current favorite is the motto batt series that have 4 post positions and include adapters that give you a lot of choices for cable attachments. Link to comment
eisenwal Posted June 15 Share Posted June 15 I like Odyssey batteries. They are not inexpensive. The one I had in my K75 lasted ten years and I only replaced it because I was getting worried it might die. Check polarity of battery so it fits your bike's configuration. Link to comment
Rougarou Posted June 15 Share Posted June 15 6 hours ago, eisenwal said: I like Odyssey batteries. They are not inexpensive. The one I had in my K75 lasted ten years and I only replaced it because I was getting worried it might die. Check polarity of battery so it fits your bike's configuration. If you go Odyssey, you gotta figure in a "special" tender/charger, as a regular tender/charger will ruin the battery. I'm not going Odyssey again. 1 Link to comment
Brodiepunker18 Posted June 15 Share Posted June 15 My bike came with the odyssey and I won’t get another one due to the higher charging requirements as noted by @Rougarou…I didn’t even know what I had until I did maintenance this spring. Duralast makes decent batteries and that would also be my choice based on price and accessibility. although that Motobatt battery intrigues me due to the unique 4 post top. And it’s not much more than the Duralast as well. Link to comment
Rotor Posted June 15 Author Share Posted June 15 Thanks to all for the input. Just ordered a Yuasa AGM. I preferred to go local and just pick it up but opted to order it. Bikes down for a bit anyway waiting on parts so no worries I guess. 2 Link to comment
lkraus Posted June 15 Share Posted June 15 I bought the Optimate 4 "CANBUS compatible" charger shortly after I bought my '06 RT in 2011. When the original battery failed in January, 2012 I bought the Odyssey PC680 because that was considered "the best". Then I discovered that the nifty new Optimate would "ruin" my expensive new battery. And that the RT also charges at less-than-optimum voltage (~14.3V). Well, crap. I was tired of spending money on the bike and farkles and decided to just use the Odyssey until it died and then try something else. So, I was riding regularly and did not use any charger for the first year. The second winter, I was avoiding cold, so the bike mostly sat for three months. I occasionally plugged in the Optimate for a few days every couple of weeks until it showed green, because something should be better than nothing and I got to use that special auxiliary port. Eventually, I actually read the Odyssey Technical Manual and found a couple of pertinent recommendations: "Determining the charger output voltage is the most important step in the charger qualification process. If the voltage output from the charger is less than 14.2V or more than 15V for a 12V battery, then do not use the charger." ( So the RTs charging voltage was just barely acceptable.) And for long life, the optimum charging method is to apply 14.7V until fully charged and then switch to a maintenance (float) mode of 13.6V. So what was the Optimate charging voltage? 13.6V. I tested my other automotive chargers and found that the old Schumacher charges at 14.7V in maintenance free/deep cycle mode, 13.7V in conventional mode. How convenient! A hour or two (since it is already mostly charged) on the Schumacher until the current drops to near zero and then switch to the Optimate for day or so and I've achieved the recommended profile. My personal feeling is that constantly being on a tender might keep a battery at its highest state of charge, but also shortens overall battery life. So I just top off the battery every 3-4 weeks when inactive, or whenever I happen to think about it. Right now, the bike has been sitting for two weeks, with no charging, and the voltage is 12.67V. The tech manual says that corresponds to an 85% state of charge. (12.84V being 100%) That's not bad for a 10.5 year old battery. I'd have no problem recommending an Odyssey, if it fits. 1 Link to comment
Brodiepunker18 Posted June 16 Share Posted June 16 2 hours ago, lkraus said: I bought the Optimate 4 "CANBUS compatible" charger shortly after I bought my '06 RT in 2011. When the original battery failed in January, 2012 I bought the Odyssey PC680 because that was considered "the best". Then I discovered that the nifty new Optimate would "ruin" my expensive new battery. And that the RT also charges at less-than-optimum voltage (~14.3V). I bought the same charger at the end of last season, and while having the bike apart for maintenance this spring I discovered I had the Odyssey…this is why I’m going to look elsewhere, IE the duralast or motobatt most likely, for a battery. also, at least on the oil heads…you can upgrade the regulator on the alternator that up’s the charging to 14.5v. I also did that this spring. Link to comment
MarinPhil Posted Monday at 10:54 PM Share Posted Monday at 10:54 PM On 6/15/2022 at 9:24 AM, Rougarou said: If you go Odyssey, you gotta figure in a "special" tender/charger, as a regular tender/charger will ruin the battery. I'm not going Odyssey again. Dont know where you get that from. 2 yrs ago i changed to an Odyssey pc680. I use an old bmw maintainer that is marked “For Gel”batteries. Sometimes it’s plugged in for 4 months while im away. No issues. Ive also used the Ctek also perfect. Link to comment
Rougarou Posted yesterday at 06:23 PM Share Posted yesterday at 06:23 PM On 6/20/2022 at 5:54 PM, MarinPhil said: Dont know where you get that from. 2 yrs ago i changed to an Odyssey pc680. I use an old bmw maintainer that is marked “For Gel”batteries. Sometimes it’s plugged in for 4 months while im away. No issues. Ive also used the Ctek also perfect. Got it directly from Odyssey and their authorized chargers after ruining a PC680 with the BMW maintainer. The BMW doesn’t push enough juice, you’re lucky so far. I currently use an authorized CTEK for that bike in snow mode. Link to comment
Sonor Posted yesterday at 07:27 PM Share Posted yesterday at 07:27 PM Call me old fashion, but I still use Westco from BeemerBoneYard. $85 and lasts three years. 1 Link to comment
