Alba Posted April 12, 2022 Share Posted April 12, 2022 Evening, So i have pulled the pin and bought a 2014 GS TE model, my intention will be do doing the servicing myself. Is there a service schedule on the forum? Thanks as ever ... Link to comment
dirtrider Posted April 12, 2022 Share Posted April 12, 2022 55 minutes ago, Alba said: Evening, So i have pulled the pin and bought a 2014 GS TE model, my intention will be do doing the servicing myself. Is there a service schedule on the forum? Thanks as ever ... Afternoon Alba You can find your service schedules here __ https://www.ascycles.com/bmw_motorcycle_service_and_maintenance_schedules#shift-cam Once your year/vehicle page is opened there is a PDF option in the left upper corner of the page. 1 Link to comment
Alba Posted April 12, 2022 Author Share Posted April 12, 2022 DR absolute gold thanks, this will allow me to crack on. I have one question at the moment on the checks, what would "Function test, engine start suppression" entail? Link to comment
DakarTimm Posted April 15, 2022 Share Posted April 15, 2022 Why is there no scheduled service for the R1200s from 2014 through 2018 ? Hard to believe they run that flawlessly .... Link to comment
dirtrider Posted April 15, 2022 Share Posted April 15, 2022 1 hour ago, DakarTimm said: Why is there no scheduled service for the R1200s from 2014 through 2018 ? Hard to believe they run that flawlessly .... Afternoon DakarTimm For the answer to this you will probably have to call, or E-Mail, A&S Powersports - http://www.aspowersports.com 1-916-726-7334 Link to comment
Skywagon Posted April 15, 2022 Share Posted April 15, 2022 ASpowersports post this on their website for 2014 and newer. It's close to the bottom of the page.There is also one for the 1250's. It is what I use. I print them out and check them off as I finish. Hope this helps. bmw_motorcycle_service_and_maintenance_schedules (ascycles.com) R1200RT K52 6000 Mile Service.pdf R1200RT K52 12000 Mile Service.pdf R1200RT K52 Annual Service.pdf Link to comment
Ozzyal Posted August 6, 2022 Share Posted August 6, 2022 On 4/13/2022 at 7:01 AM, Alba said: DR absolute gold thanks, this will allow me to crack on. I have one question at the moment on the checks, what would "Function test, engine start suppression" entail? Sorry to dig up an old thread , but I'm interested in the answer also . Link to comment
lkraus Posted August 6, 2022 Share Posted August 6, 2022 On 4/12/2022 at 5:01 PM, Alba said: DR absolute gold thanks, this will allow me to crack on. I have one question at the moment on the checks, what would "Function test, engine start suppression" entail? It's a test of the the safety switches - neutral, clutch, and sidestand. 2016 RT: (-) Function test, engine start suppression Check Set kill switch to centred position. Select neutral. Switch on the ignition. Neutral telltale light "N" lights up. Select a gear. Neutral indicator light "N" goes out. Press the starter button. Starter does not operate. Extend the side stand. Pull the clutch lever. Press the starter button. Starter does not operate. Retract the side stand. Press the starter button without releasing the clutch lever. Starter operates. Result: Not all test steps completed successfully. Measure: Check the appropriate parts with the BMW Motorrad diagnostic system 2 Link to comment
