dirtrider Posted May 19, 2022 Share Posted May 19, 2022 35 minutes ago, Newbiebmw2021 said: which one is 6 Evening Newbiebmw2021 6th fuse in from the shifter side of the motorcycle. Link to comment
Newbiebmw2021 Posted May 19, 2022 Author Share Posted May 19, 2022 ok just did the tests. all the fuses are good and i tried it with the o2 sensor disconnected and nothing. not even a hiccup of it trying to start. normally if i try to start it i smell had but nothing right now. Link to comment
dirtrider Posted May 19, 2022 Share Posted May 19, 2022 5 minutes ago, Newbiebmw2021 said: ok just did the tests. all the fuses are good and i tried it with the o2 sensor disconnected and nothing. not even a hiccup of it trying to start. normally if i try to start it i smell had but nothing right now. Evening Newbiebmw2021 OK, I'm about to sign off for tonight as I have a commitment (I won't be back until tomorrow) So one thing you can quickly try is to swap the fuel pump relay with the horn relay. (possibly that shorted o2 pigtail fried your fuel pump relay). The horn relay is the 3rd relay in from the shifter side in the front row, the horn relay is the 4th relay in from the shifter side in the front row. (just swap them then see if it will start) Link to comment
Newbiebmw2021 Posted May 19, 2022 Author Share Posted May 19, 2022 ok sounds good. thank you.have a great night Link to comment
Newbiebmw2021 Posted May 20, 2022 Author Share Posted May 20, 2022 I tried swapping relays. nothing changed ok sounds good. thank you.have a great night Link to comment
dirtrider Posted May 20, 2022 Share Posted May 20, 2022 6 hours ago, Newbiebmw2021 said: I tried swapping relays. nothing changed ok sounds good. thank you.have a great night Morning Newbiebmw2021 OK that eliminates the easy things__ So no we need to get serious. Lets go back over what was done & when it quit running? It did run until you installed that exhaust with new o2 sensor, correct? It then ran until you rode it a little, correct? THEN it wouldn't start & run, correct? You then found the o2 sensor pigtail burnt on catalytic converter & shorted between wires, correct? Here is where I am unsure-- I believe I had you disconnect the o2 sensor & it THEN started & ran (I need to know the answer to this) Then you repaired the o2 sensor pigtail the plugged it back in & now it won't start again (Is this correct???) I had you unplug the repaired o2 sensor & it still won't start , correct? (I need the answer to this also). Link to comment
Newbiebmw2021 Posted May 20, 2022 Author Share Posted May 20, 2022 good morning , it ran with the o2 sensor connected or not connected. I replaced the o2 sensor cause we thought it could be bad. after i replaced it we then put the original exhaust back on and i routed the o2 sensor wrong and when the wires burnt it stopped the bike from running along with that noise it started making from the relay. (that buzzing) because the wires shorted. it always ran with or without the o2 sensor connected. Link to comment
dirtrider Posted May 20, 2022 Share Posted May 20, 2022 10 minutes ago, Newbiebmw2021 said: good morning , it ran with the o2 sensor connected or not connected. I replaced the o2 sensor cause we thought it could be bad. after i replaced it we then put the original exhaust back on and i routed the o2 sensor wrong and when the wires burnt it stopped the bike from running along with that noise it started making from the relay. (that buzzing) because the wires shorted. it always ran with or without the o2 sensor connected. Afternoon Newbiebmw2021 I'm missing something with this. I know it WOULDN'T run with shorted o2 sensor & relays buzzing but did it run with the new o2 sensor before the wires shorted? I had you unplug the burnt wire o2 sensor & I thought you messaged me that it THEN ran with the burnt o2 sensor disconnected. HAS IT RUN with the o2 disconnected since the wires burnt????????????????????????????????????????????? Link to comment
Newbiebmw2021 Posted May 20, 2022 Author Share Posted May 20, 2022 yes it ran with it unplugged before it burnt. it never ran once the o2 sensor got burnt. Link to comment
dirtrider Posted May 20, 2022 Share Posted May 20, 2022 25 minutes ago, Newbiebmw2021 said: yes it ran with it unplugged before it burnt. it never ran once the o2 sensor got burnt. 25 minutes ago, Newbiebmw2021 said: yes it ran with it unplugged before it burnt. it never ran once the o2 sensor got burnt. Afternoon Newbiebmw2021 OK, somehow I though you had it running by disconnecting the o2 after finding the o2 sensor wires burnt. So lets move on__ Next thing to try is to remove fuse #5 (5th fuse in from shifter side) for about 20 minutes, then re-install fuse 5. Then see if it will start. If not then can you hear the fuel pump run for about 3 seconds when you turn the key on? Link to comment
Newbiebmw2021 Posted May 20, 2022 Author Share Posted May 20, 2022 did the test and it didn’t start. fuel pump does prime like it did prior to pulling the fuse. Link to comment
dirtrider Posted May 20, 2022 Share Posted May 20, 2022 11 minutes ago, Newbiebmw2021 said: did the test and it didn’t start. fuel pump does prime like it did prior to pulling the fuse. Evening Newbiebmw2021 Have you had the fuel tank removed or had the fuel tank hoses disconnected since the last time it ran? If so then make sure the hoses are connected properly. You were working with harness connectors a while back are they ALL snapped back together correctly? Are you getting a spark with the engine cranking? Are you getting 12v to the green wire at the fuel injectors for 3 seconds at key-on then full time during engine cranking? Link to comment
Newbiebmw2021 Posted May 20, 2022 Author Share Posted May 20, 2022 I will check these three things. 12 bolts at green wire during priming all hoses and connectors are reconnected. make sure spark during cranking Link to comment
Newbiebmw2021 Posted May 21, 2022 Author Share Posted May 21, 2022 evening , I checked the wires and all were plugged in. i have 12 volts at the green wire for 3 seconds when it primes. i have spark when turning over the engine. one thing i did when the gas tank was off was i cut the rubber hose connecting the drain and the vent under the tank. remember they were going into each other. other then that it’s al like it was Link to comment
dirtrider Posted May 21, 2022 Share Posted May 21, 2022 Morning Newbiebmw2021 I checked the wires and all were plugged in. --- Ok that is now accounted for. i have 12 volts at the green wire for 3 seconds when it primes. --- This is also good as it indicated the Motronic (at least fuel pump part) is working as well as your fuel pump relay is working. i have spark when turning over the engine.--- Also good so that is now accounted for. one thing i did when the gas tank was off was i cut the rubber hose connecting the drain and the vent under the tank. remember they were going into each other. other then that it’s al like it was.--- You need to add some hose to each of those fittings then route the hoses to exit just behind & slightly below the right side riders foot peg (will probably prevent a future motorcycle fire) Link to comment
dirtrider Posted May 21, 2022 Share Posted May 21, 2022 More____ You seem to have spark per your above post so HES & Motronic seem to be working (at least for spark) You now need to check for fuel flow out of the rear fuel return hose coming from the rear (not the tank end) . Should have pencil sized stream for 3 seconds at key on then continuous during engine cranking. (upper hose from rear is the fuel return hose) If you have return fuel flow per the above then you need to remove a fuel injector then with fuel line & wires still hooked up to the injector point the injector into a jar then crank the engine to see if you are getting fuel spray form the fuel injector. Be sure to point it into a catch jar or container so you don't spray fuel all over & cause a fire. Link to comment
Newbiebmw2021 Posted May 21, 2022 Author Share Posted May 21, 2022 morning dr, i will get hoses to route like you said. How do i check the first test from the return hose? I understand how to pull the injector for the second test but not sure how to do the first Link to comment
dirtrider Posted May 21, 2022 Share Posted May 21, 2022 31 minutes ago, Newbiebmw2021 said: morning dr, i will get hoses to route like you said. How do i check the first test from the return hose? I understand how to pull the injector for the second test but not sure how to do the first Afternoon Newbiebmw2021 Your motorcycle is kind of a strange beast because it has ben built form an RT into an R bike. So first we need to know if the fuel hoses on your fuel tank have quick disconnects on them? Link to comment
Newbiebmw2021 Posted May 21, 2022 Author Share Posted May 21, 2022 Yes it has quick discconnects Link to comment
dirtrider Posted May 21, 2022 Share Posted May 21, 2022 28 minutes ago, Newbiebmw2021 said: Yes it has quick discconnects Afternoon Newbiebmw2021 First thing is make absolutely sure that BOTH of your quick disconnects are FULLY pushed together. If so then move on to the below__ If they weren't solidly pushed together then push them all the way together & try starting it. The return line is the top one, you can just unplug the top quick disconnect, then you will have to use something to hold the inner check valve open on the top one coming from the rear to do you fuel flow test. Link to comment
Newbiebmw2021 Posted May 21, 2022 Author Share Posted May 21, 2022 no Gas coming out of the injector when turning the bike over gas comes out of the return line when i push the quick disconnect in Link to comment
dirtrider Posted May 22, 2022 Share Posted May 22, 2022 11 hours ago, Newbiebmw2021 said: no Gas coming out of the injector when turning the bike over gas comes out of the return line when i push the quick disconnect in Morning Newbiebmw2021 OK, IF you have a steam of fuel coming out of the rear fuel return line & have 12v going to the injectors then your problem is more than likely the fuel injectors not triggering (Motronic not pulsing the injectors on/off/on/off). You will need to put a NOID light (or 12v led) across one of the injector connectors to test this. The NOID light (or 12v led) should flash as the Motronic pulses the injectors during engine cranking. Link to comment
Newbiebmw2021 Posted May 22, 2022 Author Share Posted May 22, 2022 ok i will do this test today. i need to pickup a led light. If this is true does this mean i smoked the computer? Link to comment
dirtrider Posted May 22, 2022 Share Posted May 22, 2022 8 minutes ago, Newbiebmw2021 said: ok i will do this test today. i need to pickup a led light. If this is true does this mean i smoked the computer? Afternoon Newbiebmw2021 That is a possibility. Link to comment
Newbiebmw2021 Posted May 23, 2022 Author Share Posted May 23, 2022 ok did the test wirh a test light and it flashed when turning the ignition over. so it does work. i took a video it you want to see it. Link to comment
dirtrider Posted May 23, 2022 Share Posted May 23, 2022 Quote ok did the test with a test light and it flashed when turning the ignition over. so it does work. i took a video it you want to see it. Morning Newbiebmw2021 That isn't the best type of light to test for injector triggering but it is coming on so the injectors should be spraying. OK, according to your previous testing it has spark, has fuel coming out of the REAR fuel return line, & the injectors are triggering on. So why aren't the fuel injectors spraying fuel when cranking ???????? (we need to understand this!!!!) Are you SURE that you have a good stream of fuel coming out of the REAR (not the front) fuel return hose when the fuel pump is running? (re-check this) Every time that injector test light is ON it should be spraying fuel out of the injector so (IF) you have enough fuel pressure to open the fuel pressure regulator & push a stream of fuel out of the REAR fuel return line, & (IF) the injector is triggering on, then it SHOULD be spraying fuel. If another re-test shows a good stream of fuel flowing out of the REAR top fuel hose, & a re-test shows the injector is triggering (on) while cranking but STILL no fuel spraying out of the injector then you m-i-g-h-t have plugged injector inlet screens (small very fine filters in the fuel injector inlets). Kind of a long shot as it ran just before the o2 incident but possible. Personally I would disconnect the o2 sensor for all your remaining testing as it will start & run just fine without it connected & we don't know if the shorted pigtail effected it. (just disconnect it until you can get the engine started THEN you can plug it back in) Link to comment
Newbiebmw2021 Posted May 23, 2022 Author Share Posted May 23, 2022 good morning dr, well i don’t think i did the correct check on the return hose of fuel. when i check rhat i need to cycle it on? I just pushed it in and it flowed fuel but I realize i did the test wrong. It needs to push the fuel (hence fuel pump working) i will retest this tonight. I have learned allot from you helping me. really cool Link to comment
Newbiebmw2021 Posted May 23, 2022 Author Share Posted May 23, 2022 do i need to cycle the bike while holding the return line down or just check if gas is coming out of the return line. i did it when cycling (turning the engine over and it came out at the same speed as it did when the engine was off. gas comes out but it doesn’t come out harder when turning it over good morning dr, well i don’t think i did the correct check on the return hose of fuel. when i check rhat i need to cycle it on? I just pushed it in and it flowed fuel but I realize i did the test wrong. It needs to push the fuel (hence fuel pump working) i will retest this tonight. I have learned allot from you helping me. really cool Link to comment
dirtrider Posted May 23, 2022 Share Posted May 23, 2022 4 minutes ago, Newbiebmw2021 said: do i need to cycle the bike while holding the return line down or just check if gas is coming out of the return line. i did it when cycling (turning the engine over and it came out at the same speed as it did when the engine was off. gas comes out but it doesn’t come out harder when turning it over good morning dr, well i don’t think i did the correct check on the return hose of fuel. when i check rhat i need to cycle it on? I just pushed it in and it flowed fuel but I realize i did the test wrong. It needs to push the fuel (hence fuel pump working) i will retest this tonight. I have learned allot from you helping me. really cool Afternoon Newbiebmw2021 When you turn the key on that pressurizes the fuel rail for about 2 to 3 seconds. So you should get a short shot of fuel out as the pump runs. The return line doesn't build much pressure as the front end of that return line is open so it can't build any pressure. Then with engine turning over you should get a small steady stream of fuel flowing out. About a small pencil sized stream with an open hose but the (held open) disconnect's check valve will restrict that somewhat. Link to comment
Newbiebmw2021 Posted May 23, 2022 Author Share Posted May 23, 2022 i did a video here. Link to comment
dirtrider Posted May 23, 2022 Share Posted May 23, 2022 Afternoon Newbiebmw2021 That looks like the line coming from the front not the rear????????????????????? You need to be checking on the line that comes from the REAR! The lower line MUST be hooked up to the lower rear for the test/ Link to comment
Newbiebmw2021 Posted May 23, 2022 Author Share Posted May 23, 2022 ok. i will check the other line coming from the rear. Link to comment
Newbiebmw2021 Posted May 24, 2022 Author Share Posted May 24, 2022 here is the new video of the return hose. Gas barely comes out at the end of the test. not much at all and it took a bit for it to come out. here is the test Link to comment
dirtrider Posted May 24, 2022 Share Posted May 24, 2022 Morning Newbiebmw2021 Was the lower (pressure hose) hooked up during that test??? It didn't look like it. The lower pressure hose MUST be hooked up (snapped together) to run a return fuel flow test. Link to comment
Newbiebmw2021 Posted May 24, 2022 Author Share Posted May 24, 2022 Good morning dr, Updated Test, no fuel coming out https://youtube.com/shorts/8rYl3Nn8lAE?feature=share ie the fuel pump not working? Link to comment
dirtrider Posted May 24, 2022 Share Posted May 24, 2022 14 minutes ago, Newbiebmw2021 said: Good morning dr, Updated Test, no fuel coming out https://youtube.com/shorts/8rYl3Nn8lAE?feature=share ie the fuel pump not working? Afternoon Newbiebmw2021 It is pointing to the pump not working so are you darn SURE that you can hear the fuel pump prime for 3 seconds at key-on? Is the fuel pump pigtail connector FULLY snapped together???????? Next re-check for 12v at the green wire going to a fuel injector (3 seconds at key-on then continually during engine cranking) If green wire has 12v then Do this carefully as it could spray explosive fuel all over-- Unsnap the lower fuel disconnect then see if you have a large stream of fuel at pressure coming from FRONT HOSE. (try to point the quick disconnect into a container to catch the fuel spray) Link to comment
Newbiebmw2021 Posted May 24, 2022 Author Share Posted May 24, 2022 rechecked plug. it’s good i have 12 volts at injector and then 12 once turning it over front hose test the pressure stays the same https://youtu.be/Q4mt9yKXOVA do i need to buy the whole pump or does it come separately? Link to comment
dirtrider Posted May 24, 2022 Share Posted May 24, 2022 15 minutes ago, Newbiebmw2021 said: rechecked plug. it’s good i have 12 volts at injector and then 12 once turning it over front hose test the pressure stays the same https://youtu.be/Q4mt9yKXOVA do i need to buy the whole pump or does it come separately? Afternoon Newbiebmw2021 OK, green wire having 12v says the relays are OK. Lets not condemn the pump just yet, let's verify 12v to it first. Then if 12v to it then verify the pump ground. So next test, unplug the fuel tank electrical connector, then on the motorcycle side of that connector see if you have 12v on the green wire at key-on & during cranking. If you have 12v then do the test again but this time use the brown wire in that fuel tank connector for your meter ground point. Link to comment
Newbiebmw2021 Posted May 25, 2022 Author Share Posted May 25, 2022 Good evening Dr, Test done ✅ 12 volts at the green wire during prime and while turning over 12 volts during prime and cranking with brown wire on harness for ground. Link to comment
dirtrider Posted May 25, 2022 Share Posted May 25, 2022 6 hours ago, Newbiebmw2021 said: Good evening Dr, Test done ✅ 12 volts at the green wire during prime and while turning over 12 volts during prime and cranking with brown wire on harness for ground. Morning Newbiebmw2021 OK, that means 12v & ground is getting to the pump pigtail harness. Did that motorcycle come with those quick disconnects or did you add them after buying the motorcycle? You are probably going to have to remove the fuel tank & look at things inside. It's possible that you have a bad pump, or possibly it just blew a pressure hose off inside the tank, or even possible that it split a pressure hose inside the tank. I have even seen a few that had a high resistance 12v or ground right where the power or ground passed through the pump pass-through plate. Thing is: I keep coming back to is that it RAN OK just before the o2 sensor shorted. So what made that pump quit pumping right after that o2 pigtail repair????????????????? The pump relay was buzzing but you have 12v output from that relay now so that part seems to be OK. Difficult to believe that buzzing relay damaged your fuel pump but I suppose anything is possible. Link to comment
Newbiebmw2021 Posted May 25, 2022 Author Share Posted May 25, 2022 good morning dr, Sounds like the pump somehow took a crap somehow. I will pull the unit out of the tank tonight. I already have the tank off. I will send photos once it is out. I am also gonna drown the gas and get rid of it and put new gas in there . Link to comment
dirtrider Posted May 25, 2022 Share Posted May 25, 2022 12 minutes ago, Newbiebmw2021 said: good morning dr, Sounds like the pump somehow took a crap somehow. I will pull the unit out of the tank tonight. I already have the tank off. I will send photos once it is out. I am also gonna drown the gas and get rid of it and put new gas in there . Afternoon Newbiebmw2021 It sure could be the pump but it also could be other things, so before tearing the pump off of the pass-through plate you might want investigate further. Link to comment
Newbiebmw2021 Posted May 25, 2022 Author Share Posted May 25, 2022 Sounds good. So just pull it out and look at the whole unit like you said? Once i have it out i will post some photos. i won’t pull anything apart beyond what we discuss Link to comment
Newbiebmw2021 Posted May 26, 2022 Author Share Posted May 26, 2022 Fuel pump, Pulled it out and noticed a hose was off the pump so i reattached it and put the pump back in and the bike started and only ran for a second then blew #5 fuse. Is the pump pulling too much current? It was making a weird noise like it was working really hard before it blew the fuse. here is a photo before i reattached the hose. were it stands now is the pump is back out ready to get another pump but waiting on dr for directions . Link to comment
dirtrider Posted May 26, 2022 Share Posted May 26, 2022 4 hours ago, Newbiebmw2021 said: Fuel pump, Pulled it out and noticed a hose was off the pump so i reattached it and put the pump back in and the bike started and only ran for a second then blew #5 fuse. Is the pump pulling too much current? It was making a weird noise like it was working really hard before it blew the fuse. here is a photo before i reattached the hose. were it stands now is the pump is back out ready to get another pump but waiting on dr for directions . Morning Newbiebmw2021 First thing, that pump assembly has the incorrect hose clamps, that hose or hoses will probably blow off again in the future if you don't use the correct (high pressure) fuel injection hose clamps. Those worm gear type clamps keep sinking into the hose then won't hold the high pressure hoses on. This is BAD if it happens a long ways from home. Not even that good if it happens in your driveway. OK, now on your fuse blowing?-- Are you DARN SURE that it is fuse #5 & not fuse #6 blowing? If it is fuse #5 then it probably isn't the fuel pump blowing the fuse. If it is fuse #6 then it could be the fuel pump blowing the fuse. Did you disconnect the o2 sensor like I asked you to in my above post??????????????????????__ If not then DO THAT! A problem with the o2 sensor can blow fuse #5. Note: the proper F.I. hose clamps don't have all those little worm drive slits in them to dig (sink) into the high pressure hoses. 1 Link to comment
Doctor T Posted May 26, 2022 Share Posted May 26, 2022 This is where forums come in to their own. Fellow bikes helping bikes. Well done to D.R trying to sourt this out and good luck to the OP. 2 1 Link to comment
dirtrider Posted May 26, 2022 Share Posted May 26, 2022 Morning Newbiebmw2021 More____ It looks like your internal fuel tank vent & drain is plugged off. You can probably live with the drain plugged off but you absolutely need to have a working tank vent. While it is apart you should probably look into getting your tank vent re-plumbed correctly. (unfortunately the submersible fuel hose needed for the internal venting is very expensive) Link to comment
Newbiebmw2021 Posted May 26, 2022 Author Share Posted May 26, 2022 I am sorry i meant fuse 6. So i need to order vent hose fi injection clamps should i order a pump also? Link to comment
dirtrider Posted May 26, 2022 Share Posted May 26, 2022 5 minutes ago, Newbiebmw2021 said: I am sorry i meant fuse 6. So i need to order vent hose fi injection clamps should i order a pump also? Afternoon Newbiebmw2021 You should probably replace all the in-tank hoses as the high pressure hoses tend to get weak with age then fuel at the worst possible times. Before ordering a new pump what was the amp rating of the #6 fuse that failed? Link to comment
