Dingo55 Posted January 9, 2022 Share Posted January 9, 2022 Hi all Appreciate any help Looking at a 2012 R1200rt Only 5000 km on the clock Is this of any concern in regard to maybe not having been " run in " properly? Apparently it has been serviced yearly ( you would wonder why you would bother) Any way of checking whether going to end up with a oil burner? Cheers Mark Link to comment
dirtrider Posted January 9, 2022 Share Posted January 9, 2022 1 hour ago, Dingo55 said: Hi all Appreciate any help Looking at a 2012 R1200rt Only 5000 km on the clock Is this of any concern in regard to maybe not having been " run in " properly? Apparently it has been serviced yearly ( you would wonder why you would bother) Any way of checking whether going to end up with a oil burner? Cheers Mark Morning Mark You are posting in the oilhead forum here but you are asking about a camhead motorcycle. But not a big deal as most camhead posters will still find your post here. Future posts should probably go in the camhead forum. On your "run in " question, no way to really know as it's the first 1000 km's that are the most important & even then most do break-in properly without any special treatment. You might be able to see some signs of oil burning on the spark plugs if the owner will allow those to be removed & inspected. Link to comment
