Acidburn Posted May 23, 2006 Share Posted May 23, 2006 I am so impressed with the Braking Rotors i installed on my 1100s i am getting a set for the 04-Rt. I am hoping the super consistant and very linear performance of the ones on the -S- translate a tiny bit to the suck brake set up on the Rt. Link to comment
BMW_Ken Posted May 23, 2006 Share Posted May 23, 2006 I am so impressed with the Braking Rotors i installed on my 1100s i am getting a set for the 04-Rt. Brand/model that you plan to install on the RT? Thanks. Link to comment
philbytx Posted May 23, 2006 Share Posted May 23, 2006 Your stock 2004 RT has a suck brake set-up and you improved the braking with new rotors? Can you enlighten me as to why they sucked (being as the stock RT has excellent brakes) and how new rotors improved the braking.......? Link to comment
Acidburn Posted May 24, 2006 Author Share Posted May 24, 2006 its a grabby very sensitive nonlinear system, i did not say it does not stop good, too good, the 1100s improved with the linearity of the Braking rotors, i am hoping this helps smooth out the application just a bit on the Rt. Same numbers as the 1100s, i dont know, Santa Cruz BMW has the numbers. Link to comment
