Ponch Posted December 6, 2021 Share Posted December 6, 2021 If I needed one, how difficult is that to get? Link to comment
Ponch Posted December 8, 2021 Author Share Posted December 8, 2021 I'd delete it if I could. Just hate going to the dealers in my area and for all I know they don't offer to replace keys anymore. Link to comment
dirtrider Posted December 8, 2021 Share Posted December 8, 2021 On 12/6/2021 at 5:55 PM, Ponch said: If I needed one, how difficult is that to get? Evening Ponch Not difficult to get but it is ONLY a dealer furnished item & you have to take in proof of ownership (usually the title). Not a cheap key to buy & usually takes a few days to get. It is coded a chip so without a proper chip in the key that the antenna ring can read it just won't start & no easy way to defeat the system. Link to comment
Rinkydink Posted December 9, 2021 Share Posted December 9, 2021 Take title AND registration just to be sure. I even took proof of insurance also. I’m anal that way, and this was just for an additional fob. Link to comment
Ponch Posted December 9, 2021 Author Share Posted December 9, 2021 I have the remnants of the plastic key(it has the RFID chip in it) and I have the GSK code doohickey. I have to see if I have a title. In AZ they went digital/DMV has it. What's not cheap? Link to comment
dirtrider Posted December 9, 2021 Share Posted December 9, 2021 1 hour ago, Ponch said: I have the remnants of the plastic key(it has the RFID chip in it) and I have the GSK code doohickey. I have to see if I have a title. In AZ they went digital/DMV has it. What's not cheap? Evening Ponch If you have the RFI part of the plastic key then you c-o-u-l-d cheat the system by unbolting the ignition switch antenna, then taping (or fastening) the RFI part of your old key into the antenna ring, then zip tying the antenna ring in a safe location. This should allow any key that fits/works in your ignition switch to function & start the engine. But this assumes that you have a functional metal key to get copied. Or you might be able to buy a non-chipped key from BMW using just the motorcycle serial number. If you bought the bike new from a local dealer there might be a (chipped) 2nd metal key in their possession (some hexheads came with 2 metal keys & a plastic key with the dealer keeping the 2nd metal key). My 2009 hexhead came with 2 metal keys & a plastic key, I talked (pretty well forced) the dealer to give me that 2nd metal key. (might be worth a try) Link to comment
Scott9999 Posted December 9, 2021 Share Posted December 9, 2021 36 minutes ago, dirtrider said: Evening Ponch If you have the RFI part of the plastic key then you c-o-u-l-d cheat the system by unbolting the ignition switch antenna, then taping (or fastening) the RFI part of your old key into the antenna ring, then zip tying the antenna ring in a safe location. This should allow any key that fits/works in your ignition switch to function & start the engine. But this assumes that you have a functional metal key to get copied. Or you might be able to buy a non-chipped key from BMW using just the motorcycle serial number. If you bought the bike new from a local dealer there might be a (chipped) 2nd metal key in their possession (some hexheads came with 2 metal keys & a plastic key with the dealer keeping the 2nd metal key). My 2009 hexhead came with 2 metal keys & a plastic key, I talked (pretty well forced) the dealer to give me that 2nd metal key. (might be worth a try) Interesting comment. Sidebar Question: Why would the dealer keep the second metal, RFID'd key, if they have sold, and no longer own the bike? Can they re-use them? Recode and sell them? BMW (and it's dealers) is weird, sometimes. Link to comment
Skywagon Posted December 9, 2021 Share Posted December 9, 2021 Mine came with 2 metal keys, a plastic key, a plastic RFI chip, and they gave me some sort of a code that said if I ever needed a key bring this code as it is all we need. 15 minutes ago, Scott9999 said: Can they re-use them? Recode and sell them? Interesting question. Hope someone knows. I would have assumed they kept it as an emergency key for the owner...but thats kind of like asking my wife to hold my wallet so I don't spend any money. Link to comment
dirtrider Posted December 9, 2021 Share Posted December 9, 2021 29 minutes ago, Scott9999 said: Interesting comment. Sidebar Question: Why would the dealer keep the second metal, RFID'd key, if they have sold, and no longer own the bike? Can they re-use them? Recode and sell them? BMW (and it's dealers) is weird, sometimes. Evening Scott Reason I was given was BMW's recommendation in case the metal & plastic key were lost by owner, they (the dealer) retained a working key for the owner. (I think the BMS-K only has 10 addresses available (7 left after original 3 keys) for new key programming. The dealer might also have a use for that key if the motorcycle was broken down & left somewhere with no key from owner handy to use for vehicle recovery. I know my dealer held the 2nd key & I have talked to others that their dealer did the same thing. Again, I'm not sure if all hexheads came with that 2nd key, or just some of the later ones, or just some dealers requested one from BMW. I know mine came with the 2nd key. Luckily I knew of that 2nd key as the dealer never mentioned it to me until I sort of forced them to address it & even then they tried their darndest to not give me that 2nd key. 1 Link to comment
Ponch Posted December 12, 2021 Author Share Posted December 12, 2021 On 12/9/2021 at 2:39 PM, dirtrider said: Evening Ponch If you have the RFI part of the plastic key then you c-o-u-l-d cheat the system by unbolting the ignition switch antenna, then taping (or fastening) the RFI part of your old key into the antenna ring, then zip tying the antenna ring in a safe location. This should allow any key that fits/works in your ignition switch to function & start the engine. But this assumes that you have a functional metal key to get copied. Or you might be able to buy a non-chipped key from BMW using just the motorcycle serial number. If you bought the bike new from a local dealer there might be a (chipped) 2nd metal key in their possession (some hexheads came with 2 metal keys & a plastic key with the dealer keeping the 2nd metal key). My 2009 hexhead came with 2 metal keys & a plastic key, I talked (pretty well forced) the dealer to give me that 2nd metal key. (might be worth a try) I had two keys(lost the other one 5 or 6 years ago), the plastic key and the key code. The plastic key broke, but I kept the chip part. Some good news though, I found the key. Now to make a copy. It would have ended up in the trash had I not found it. Link to comment
ian408 Posted December 12, 2021 Share Posted December 12, 2021 On 12/6/2021 at 2:55 PM, Ponch said: If I needed one, how difficult is that to get? For BMW, you will need proof of identity and proof of ownership. A driver's license and registration is good. Keys are cut in Stockton and generally take a couple of days to get. Depending on model year, you may also want to schedule a service appointment to code the keys to your bike if you lost the key. Link to comment
dirtrider Posted December 12, 2021 Share Posted December 12, 2021 5 hours ago, ian408 said: For BMW, you will need proof of identity and proof of ownership. A driver's license and registration is good. Keys are cut in Stockton and generally take a couple of days to get. Depending on model year, you may also want to schedule a service appointment to code the keys to your bike if you lost the key. Morning ian408 If they have (or have access to) a GS-911 then the (lost key) can be disabled in the BMS-K (not necessary but usually desirable), then new key can be enabled in the BMS-K using the GS-911. Link to comment
r100rs88@gmail.com Posted December 29, 2021 Share Posted December 29, 2021 You can also just buy https://www.amazon.com/dp/B096WVBGKC/ref=cm_sw_em_r_mt_dp_2HY8NSR8V4B34Y8T6EF8?_encoding=UTF8&psc=1 and have the metal part of the key cut and put the Chip in the head. I have done it with mine and it works well. 1 Link to comment
ian408 Posted March 17, 2022 Share Posted March 17, 2022 On 12/12/2021 at 5:14 AM, dirtrider said: Morning ian408 If they have (or have access to) a GS-911 then the (lost key) can be disabled in the BMS-K (not necessary but usually desirable), then new key can be enabled in the BMS-K using the GS-911. It's been a while but I don't recall that the GS-911 deals with keys. Which version? Do you remember? Link to comment
dirtrider Posted March 17, 2022 Share Posted March 17, 2022 9 hours ago, ian408 said: It's been a while but I don't recall that the GS-911 deals with keys. Which version? Do you remember? Morning ian408 The newer (red) WiFi versions should have a function under -- CONTROLLER SERVICE BMSK ENGINE CONTROLLER Link to comment
