Shelterwoods Posted November 24, 2021 Share Posted November 24, 2021 I have noticed that as the tires wear on my R1250-RS, the handling becomes decidedly heavy. I am new to the BMW brand, and haven't noticed as dramatic a change on other bikes I've owned. I am on my second set of tires, Metzler Roadtec 01's replaced the Metzler 07's that came with the bike. With both sets, as 7,000 miles approach, the handling becomes heavy, requiring much more effort to turn in to a corner. The 01's profile is probably flatter now because of a 4,000 mile ride to Phoenix than the 07's had at 7,000 miles, but they both exhibited the same handling characteristics. When new, both sets were very nice. I look forward to your feedback. Del Link to comment
Bernie Posted November 24, 2021 Share Posted November 24, 2021 Try to increase your front air pressure to 38-40 psi. Link to comment
dirtrider Posted November 24, 2021 Share Posted November 24, 2021 1 hour ago, Shelterwoods said: I have noticed that as the tires wear on my R1250-RS, the handling becomes decidedly heavy. I am new to the BMW brand, and haven't noticed as dramatic a change on other bikes I've owned. I am on my second set of tires, Metzler Roadtec 01's replaced the Metzler 07's that came with the bike. With both sets, as 7,000 miles approach, the handling becomes heavy, requiring much more effort to turn in to a corner. The 01's profile is probably flatter now because of a 4,000 mile ride to Phoenix than the 07's had at 7,000 miles, but they both exhibited the same handling characteristics. When new, both sets were very nice. I look forward to your feedback. Del Morning Del Just about every large newer BMW that I have owned does that. As the tires get miles on them the center of the tire wears flat in relation to the off-center areas so the tire turn-in gets slower & more sluggish as the miles accumulate. The rear seems just as bad as the front at slowing down the turn-in so it isn't only a front tire wear deal. I have found that lowering the air pressure slightly seems to help a little as that allows a bit more tire wear off-center. Long hauls on the interstate adds to the problem as that puts just about ALL the tire wear on just that center strip due to air pressure gain & straight line riding so that can then flatten the center off pretty quickly. I'm a pretty aggressive rider so do wear the tires off-center pretty heavily but still manage to wear the centers flat enough to effect turn-in. The only up-side I have to riding aggressively is that means I usually get less than 6K miles on the tires so I do get that new-tire turn-in feel fairly often. Link to comment
dirtrider Posted November 24, 2021 Share Posted November 24, 2021 8 minutes ago, dirtrider said: Morning Del Just about every large newer BMW that I have owned does that. As the tires get miles on them the center of the tire wears flat in relation to the off-center areas so the tire turn-in gets slower & more sluggish as the miles accumulate. The rear seems just as bad as the front at slowing down (numbing down) the turn-in so it isn't only a front tire wear deal. I have found that lowering the air pressure slightly seems to help a little as that allows a bit more tire wear off-center. Long hauls on the interstate adds to the problem as that puts just about ALL the tire wear on just that center strip due to air pressure gain & straight line riding so that can then flatten the center off pretty quickly. I'm a pretty aggressive rider so do wear the tires off-center pretty heavily but still manage to wear the centers flat enough to effect turn-in. The only up-side I have to riding aggressively is that means I usually get less than 6K miles on the tires so I do get that new-tire turn-in feel fairly often. Link to comment
Hosstage Posted November 24, 2021 Share Posted November 24, 2021 Very noticeable on my Harleys. Link to comment
Beech Posted March 5, 2022 Share Posted March 5, 2022 7000 miles on Metzler 7RR's they are worn out. These are sport leaning tires, good but go south quickly. My K bike eats tires by 4500 miles on a good day (m7RR's). Get more in tune with your tires, many brands are worn out before they look it. This is especially true for Michelin PR series tires. Less than 1.5 mm tread is super worn out an illegal Germany. As mentioned pay special attention to your tire pressures. Check once a week. A pound or two will change things. 1 Link to comment
Shelterwoods Posted March 5, 2022 Author Share Posted March 5, 2022 Beech, thank you for your information. I just replaced my tires at about 7,000. I went back to Metzler 08's as I couldn't find the 01's in the size. Either tire gets very thin in the center well before the tread wear indicators are near the tread surface, so I'm going to start changing earlier, perhaps at 5,500 or 6,000. Del Link to comment
Shelterwoods Posted March 5, 2022 Author Share Posted March 5, 2022 Beech, do you know what the German standards are? It would be nice to have this reference. Del Link to comment
