Monte Sloan Jr Posted November 17, 2021 Share Posted November 17, 2021 Me again, Put new tire on the Beemer. I was riding home when the caution triangle started flashing on the dash. then my TPMS came on with the front tire in red. I pulled over and found the tire was fine , not flat or losing any air. It cleared itself and showed the tire pressure. kinda scary. Well it did it again today, is the battery dying in the sensor ? Please help, thank you Link to comment
Boxflyer Posted November 17, 2021 Share Posted November 17, 2021 Hi Monte, Where do you live? I've got half a dozen or so replacement TPMS for both RT/RS/R as well as GS/GSA rims, if you are close, I can install and program a new one. Boxflyer Link to comment
RandyShields Posted November 17, 2021 Share Posted November 17, 2021 I want to move to be closer to Brad. Well, at least in the summer. 1 1 Link to comment
wbw6cos Posted November 17, 2021 Share Posted November 17, 2021 He would make one hell of a neighbor!! He is also a pretty good guy. 2 Link to comment
Boxflyer Posted November 17, 2021 Share Posted November 17, 2021 HaHa! Once you found out that I use my pellet smoker to make pork ribs and pulled pork about twice a week, I'd have a hard time keeping you away! Brad (How 'bout this for thread drift!!!) 1 1 1 Link to comment
Monte Sloan Jr Posted November 17, 2021 Author Share Posted November 17, 2021 11 hours ago, Boxflyer said: Hi Monte, Where do you live? I've got half a dozen or so replacement TPMS for both RT/RS/R as well as GS/GSA rims, if you are close, I can install and program a new one. Boxflyer Hi Boxflyer, I live in Petaluma California. So the TPMS is gone bad correct ? or does it need a new battery ? A new one needs to be programmed ? Thanks, buddy Link to comment
Boxflyer Posted November 17, 2021 Share Posted November 17, 2021 8 minutes ago, Monte Sloan Jr said: So the TPMS is gone bad correct ? or does it need a new battery ? A new one needs to be programmed ? Well, it could be, and most likely is the sending unit battery. If you want to put some effort into the battery replacement, that "might" work...or you could just be frustrated with a waste of time. My preferred approach to a malfunctioning TPMS is simply to replace it and train the RDC to accept the new serial number of the sending unit. This is a little far ranging, covering somewhat more than just a Remove and Replace...but it has lots of info for you. Hope this helps. R1200RTW TPMS Programing with the GS-911 2 Link to comment
Monte Sloan Jr Posted November 18, 2021 Author Share Posted November 18, 2021 Cool, thank you. Link to comment
Monte Sloan Jr Posted December 2, 2021 Author Share Posted December 2, 2021 Hi Boxflyer, I have a 911 unit. How much do you want for a front and rear TPMS unit ? I will input the numbers manually, no problem. I used to live in Wagener, South Carolina. I was a buyer for Nucor Steel. Please let me know what you want for the 2 sensors. Thank you. Link to comment
