14TLC Posted November 10, 2021 Share Posted November 10, 2021 Hi Everyone Does anyone know the resistance values for given temperature for Air temperature sensors on R1100 and R1150? I have these values but I am not sure if they are correct and for which sensor they are. One of them should be for R1100 and the other for R1150. I don't have a sensor near me to compare them Temperature (°C) / Resistance (ohm) 0 / 5900 10 / 3800 20 / 2500 30 / 1700 40 / 1170 50 / 830 60 / 590 70 / 430 80 / 310 90 / 240 100 / 180 Temperature (°C) / Resistance (ohm) 0 / 16325 10 / 9950 20 / 6249 30 / 4029 40 / 2664 50 / 1802 60 / 1244 70 / 876 80 / 628 90 / 458 100 / 339 Link to comment
dirtrider Posted November 10, 2021 Share Posted November 10, 2021 7 minutes ago, 14TLC said: Hi Everyone Does anyone know the resistance values for given temperature for Air temperature sensors on R1100 and R1150? I have these values but I am not sure if they are correct and for which sensor they are. One of them should be for R1100 and the other for R1150. I don't have a sensor near me to compare them Morning 14TLC Yes, I have the values for both but all my data is if (Fahrenheit) not (Celsius). If you do the conversions then re-post I will compare to my data. I'm in a meeting right now so don't have the time to do the conversions at the momment. Link to comment
14TLC Posted November 10, 2021 Author Share Posted November 10, 2021 2 minutes ago, dirtrider said: If you do the conversions then re-post I will compare to my data. Of course, here they are Temperature (°F) / Resistance (ohm) 32 / 5900 50 / 3800 68 / 2500 86 / 1700 104 / 1170 122 / 830 140 / 590 158 / 430 176 / 310 194 / 240 212 / 180 Temperature (°F) / Resistance (ohm) 32 / 16325 50 / 9950 68 / 6249 86 / 4029 104 / 2664 122 / 1802 140 / 1244 158 / 876 176/ 628 194/ 458 212 / 339 Link to comment
dirtrider Posted November 10, 2021 Share Posted November 10, 2021 Morning The top one above most closely follows my 1150 IAT chart (your (C) conversions don't match my (F) chart as I did mine on evenly spaced (F) numbers but enough match up to say the top one 32 / 5900 -- 212 / 180 is the 1150 sensor. Are you sure that other sensor that you have is an 1100? It more closely follows my 1200RT IAT chart. Link to comment
14TLC Posted November 10, 2021 Author Share Posted November 10, 2021 To be honest I am not sure that the other one is an 1100 sensor. I thought so, but apparently is not. Could you post the values you have for 1100 sensor, even though they are in F Link to comment
dirtrider Posted November 10, 2021 Share Posted November 10, 2021 1 hour ago, 14TLC said: To be honest I am not sure that the other one is an 1100 sensor. I thought so, but apparently is not. Could you post the values you have for 1100 sensor, even though they are in F Afternoon 14TLC Actually I won't post the numbers as they haven't been verified with precision equipment & I refuse to post unverified data under my screen name. I took the 1100 IAT data a long time ago (early in 1995). I have since plugged the numbers into a known NTC (Negative Temperature Coefficient) table & they don't totally mirror a proper temp vs resistance table (some points are real close & others are off a bit). The 1100 values I have on hand & originally tested are very close to the 1150 sensor values. Back in the 1100 (Ma 2.2) era a lot of us 1100 riders removed the CCP then ran them open loop, so some of us did a lot of playing with the (Intake Air Sensor) output signal to spoof it & try to tune the fueling slightly with IAT (intake temperature) off-set. Once the 1150 Ma 2.4 came out that kind of went away as most 1150 (Ma 2.4) bikes ran better in closed loop so with the o2 sensor operational spoofing the IAT did no good as the fueling computer just learned the spoofing off-sets then re-learned around the spoofing & even applied those re-learned adaptives to the open loop portion of the fueling control. On the later BMW motorcycles, if you are trying to build an IAT spoofer, then to achieve any lasting effect you will have to disable the o2 sensor, then clear the learned fueling adaptives, then run open loop (no functioning o2 sensor). What are you working on? Link to comment
JamesW Posted November 11, 2021 Share Posted November 11, 2021 Isn't that about the truth D.R. when you describe the difference between a 2.2 vs a 2.4 motronic and how easy it is to just snip the CCP jumper and all your fueling issues are gone. Hindsight is 20-20 and if I were looking for an oilhead BMW I wouldn't consider an 1150. When I owned my 1150 I spent hours and days trying everything to get the thing to run correctly and I was pretty successful in the end. I experimented with the AIT sensor very early on without success. The 2.4 adaptive motronic just won't cooperate. Only thing that works is an AFXIED or an Innovate Motor Sports LC-1 or LC-2. Link to comment
14TLC Posted November 11, 2021 Author Share Posted November 11, 2021 10 hours ago, dirtrider said: The 1100 values I have on hand & originally tested are very close to the 1150 sensor values. Does this mean that 1150 sensor can be used on a 1100 and vice versa? What about on a 1100 with CO Pot, without O2 sensor and CAT ? How much difference it would make to use a 1150 sensor on such 1100 model? Link to comment
dirtrider Posted November 11, 2021 Share Posted November 11, 2021 4 hours ago, 14TLC said: Does this mean that 1150 sensor can be used on a 1100 and vice versa? What about on a 1100 with CO Pot, without O2 sensor and CAT ? How much difference it would make to use a 1150 sensor on such 1100 model? Morning 14TLC Does this mean that 1150 sensor can be used on a 1100 and vice versa?-- Good question, I can't remember ever doing that (might have but I don't have any data on doing it). As I mentioned above I did some IAT spoofing/testing on the 1100 (Ma 2.2) What about on a 1100 with CO Pot, without O2 sensor and CAT ? -- There is something to be gained by playing with the IAT resistance on the open loop 1100 (Ma 2.2) systems, at least above idle where the Co pot has less effect. How much difference it would make to use a 1150 sensor on such 1100 model? -- I really can't answer this, this is probably worth investigating but unfortunately using a GS-911 on the 1100 Ma 2.2 system won't give you IAT (Intake Air) temperatures so it would have to be done using a thermocouple in the air box vs IAT sensor resistance. The problem with comparing the 1100 (MA 2.2) to the 1150 (Ma 2.4) is most of us that were playing with these things worked with the 1100 (MA 2.4) well before the 1150 (Ma 2.4) was released for production. Then once the 1150 (Ma 2.4) came out THAT was our focus so we we didn't re-address cross model sensor swapping. Link to comment
14TLC Posted November 11, 2021 Author Share Posted November 11, 2021 Thank for your inputs dirtrider. Next week I might have one R1100GS with MA 2.2 in my garage. Owner complaining about overly rich running condition and increased fuel consumption. The IAT sensor will be on the list of things to be checked. So, I will have the opportunity to make measurements and compare data. Will post the values here Link to comment
14TLC Posted November 19, 2021 Author Share Posted November 19, 2021 Good morning everyone, The mentioned R1000GS arrived yesterday and I had the chance to measure the IAT. Here are the values. The scale of thermometer I used is in 2 degrees increments, thus the x6 values Temperature (°C) Temperature (°F) Resistance (ohm) 16 60.8 4000 20 68 3181 26 78.8 2663 30 86 2237 36 96.8 1753 40 104 1520 46 114.8 1200 50 122 1045 56 132.8 843 60 140 715 66 150.8 614 70 158 531 76 168.8 442 80 176 388 86 186.8 328 90 194 290 96 204.8 245 100 212 220 Link to comment
14TLC Posted November 19, 2021 Author Share Posted November 19, 2021 On 11/11/2021 at 6:52 AM, JamesW said: and if I were looking for an oilhead BMW I wouldn't consider an 1150 Me also. In my taste, the R1000 is just a sweet running machine compared to the R1150 Link to comment
dirtrider Posted November 19, 2021 Share Posted November 19, 2021 On 11/19/2021 at 3:24 AM, 14TLC said: Good morning everyone, The mentioned R1000GS arrived yesterday and I had the chance to measure the IAT. Here are the values. The scale of thermometer I used is in 2 degrees increments, thus the x6 values Temperature (°C) Temperature (°F) Resistance (ohm) 16 60.8 4000 20 68 3181 26 78.8 2663 30 86 2237 36 96.8 1753 40 104 1520 46 114.8 1200 50 122 1045 56 132.8 843 60 140 715 66 150.8 614 70 158 531 76 168.8 442 80 176 388 86 186.8 328 90 194 290 96 204.8 245 100 212 220 Afternoon 14TLC I plotted the IAT data you posted_ That looks to be a fairly representative 1100 temp vs resistance curve, couple of small irregularities but overall pretty decent. Link to comment
14TLC Posted November 19, 2021 Author Share Posted November 19, 2021 Thank you dirtrider, Good to know this, I now have reference values for R1100 IAT which I thought that I have but turned out to be R1200 IAT values. Thank you for that also. Now to tackle the rich running condition and fuel consumption of this particular R1100GS Link to comment
