eyalcan Posted November 9, 2021 Share Posted November 9, 2021 Looking to install 5" handlebar risers on 2002 R1150R and will need longer cables such as Choke, Throttle, Clutch and front Brake hoses, Do R1150 RT cables can fit mine? Link to comment
dirtrider Posted November 9, 2021 Share Posted November 9, 2021 1 hour ago, eyalcan said: Looking to install 5" handlebar risers on 2002 R1150R and will need longer cables such as Choke, Throttle, Clutch and front Brake hoses, Do R1150 RT cables can fit mine? Evening eyalcan They s-h-o-u-l-d fit but I can't guarantee that the 1150RT cables will fit your 1150R controls but the choke lever seems to be the same so that should probably fit. You do gain a little length on the CHOKE CABLE length__ see below__ But it looks like you LOSE a little length on the ACCELERATOR CABLE length__ see below__ 1150R--- ACCELERATOR CABLE - L=1115MM (to 12/04) CHOKE CABLE - L=1037MM 1150RT--- ACCELERATOR CABLE - L=1070MM CHOKE CABLE - L=1059MM Link to comment
eyalcan Posted November 10, 2021 Author Share Posted November 10, 2021 Thank you so much Link to comment
