MoteroNC Posted November 6, 2021 Share Posted November 6, 2021 On my 09 R1200RT I now have a constant TPM warning and no PSI readings. I believe it may be coming from the front tyre TPM. Is there any way to wake up the system or force a reset without the use of the dealer tool? Was wondering if disconnecting battery may reinitiate system? Link to comment
dirtrider Posted November 6, 2021 Share Posted November 6, 2021 1 hour ago, MoteroNC said: On my 09 R1200RT I now have a constant TPM warning and no PSI readings. I believe it may be coming from the front tyre TPM. Is there any way to wake up the system or force a reset without the use of the dealer tool? Was wondering if disconnecting battery may reinitiate system? Afternoon MoteroNC Riding it usually wakes up the in-wheel sensor if it's battery is good. Good possibility that your front wheel pressure sensor (the one inside the tire/wheel) has a dead battery. That battery is pretty well non replaceable unless you know how to take the sensor apart, then re-solder & re-pot a new battery. Some sensor wakeup tools can read the battery voltage (your dealer can probably do that for you), possibly a local auto parts store has a tool that will read the sensor battery voltage. Link to comment
