Clutch lever switch or side stand
GordonB
2012RT
Stopped to fill up for gas and out of nowhere my bike will not start; In first clutch lever pulled with side stand up.
It will start in Neutral.
Engine will shut off if you deploy side stand engine running in first with clutch pulled.
Yes I can hear the micro switches clicking as I pull the clutch lever.
Faulty clutch lever switch?
Thanks
10 hours ago, GordonB said:
2012RT
Thanks
Morning   GordonB
It does sound like a clutch lever switch issue (bad switch or bent lever reed), with trans in neutral the clutch switch or side strand switch isn't  needed to start.
If your motorcycle has cruise control then it has a dual clutch switch so the cruise switch part could be what you hear clicking.
