poodad Posted October 14, 2021 Share Posted October 14, 2021 Seems a bit backwards to me. Link to comment
duckbubbles Posted October 14, 2021 Share Posted October 14, 2021 Are they the same sizes? Previously switched is my guess. Frank Link to comment
dirtrider Posted October 14, 2021 Share Posted October 14, 2021 4 hours ago, poodad said: Seems a bit backwards to me. Morning poodad Did you look closely at the drain plug? Plugs are different sizes 14mm vs 18mm but my BMW parts book shows them both as magnetic plugs. Link to comment
Lowndes Posted October 14, 2021 Share Posted October 14, 2021 It's for when your valves start floating. Link to comment
poodad Posted October 15, 2021 Author Share Posted October 15, 2021 On 10/14/2021 at 10:12 AM, dirtrider said: Morning poodad Did you look closely at the drain plug? Plugs are different sizes 14mm vs 18mm but my BMW parts book shows them both as magnetic plugs. The drain plug had a flat surface and no goo. I guess my drain plug could be non OEM, but I doubt it. Link to comment
dirtrider Posted October 15, 2021 Share Posted October 15, 2021 6 minutes ago, poodad said: The drain plug had a flat surface and no goo. I guess my drain plug could be non OEM, but I doubt it. Afternoon poodad Just because the BMW parts book lists it doesn't mean that BMW didn't make a running change & eliminate it during production, or their supplier couldn't deliver on time for production, or possibly it was produced without the magnetic drain plug & BMW now only services the magnetic plug as a replacement. Or possibly some dealer tec dropped it or damaged it then just grabbed as standard plug from stock to replace the lost or damaged one. Link to comment
beemer chuck Posted December 7, 2021 Share Posted December 7, 2021 My 2010 is like this also. Was the Miami BMW dealers personal bike, so I doubt any plugs were switched. Link to comment
