Jerry Johnston Posted May 20, 2006 Share Posted May 20, 2006 Some of you may have already found that a 20mm multi-faceted socket fits the knobs, allowing you to use a socket set and extention to remove and tighten them. Obviously you don't want to over tighten them but you don't want the tail light dangling behind you either. Link to comment
bmwscoot Posted May 20, 2006 Share Posted May 20, 2006 I also remember from a while back... someone posted that they wrapped rubber bands around the studs behind those nuts to keep them from falling off if they loosened up. Link to comment
Kurt Snyder Posted May 21, 2006 Share Posted May 21, 2006 I replaced mine with self locking nuts. I added a 10 mm socket to my tool kit for removal on the road. 1995 R1100RSL Kurt Link to comment
FrankT Posted May 21, 2006 Share Posted May 21, 2006 I did the same as Kurt, snug tight only, bought the locknuts at Ace Hardware. The plastic thumbwheels that come stock are the same as those used at the rear gas tank hold-downs on a /6 and later but don't cut it for the RT rear tail light. Link to comment
