adventurer2112 Posted September 12, 2021 Share Posted September 12, 2021 Hi Just bought 97 R1100RT 84 K miles. + PO installed Ohlins, SS brake lines, Twin Max synched throttle bodies, new tires. - Front engine cover melted a little bit. PO put 8 15 amp fuses in box. Put correct fuse amps in. Front brake sticks, I have to move brake lever forward to unstick front brake. Would a front brake rebuild fix this or so I need to buy the $400 front brake from Beemer boneyard. Or is there something else that might work ? im going to change all fluids. Bought an alternator pulley belt, spark plugs, spark plug wires, HE s, quick fuel disconnects. Fuel / submersible fuel hoses, ,air, oil filters.front engine cover. Installed a good RID., but broke dash board. Plasti welded, good for now. Any other recommendations? Jack Link to comment
adventurer2112 Posted September 12, 2021 Author Share Posted September 12, 2021 Hi Also idiot gas light lit but RID doesn’t light up. how do I calibrate the 2, so they are in sync? thanks in advance. Jack Link to comment
fatbob Posted September 12, 2021 Share Posted September 12, 2021 Jack: the RID doesn’t light up when the low fuel light comes on. How many bars did the fuel gage read when the low fuel light came on? One or two? I suspect a master cylinder rebuild on the front brakes will cure the sticking issue. Link to comment
szurszewski Posted September 12, 2021 Share Posted September 12, 2021 Fuel gauge and low fuel warning light are totally separate systems. The gauge sensor is a float in a tube. The light is a float on an arm. There are some common failures and fixes for the tube system. Is your readout stuck at a certain number of bars, or is there no fuel display at all? Link to comment
adventurer2112 Posted September 12, 2021 Author Share Posted September 12, 2021 Hi Thanks for the quick responses. 2 bars on RID when idiot gas light would intermittently flash yellow. 7 bars after non - ethanol fill up.? Rear brake pulses when used singely. Link to comment
dirtrider Posted September 12, 2021 Share Posted September 12, 2021 18 minutes ago, adventurer2112 said: Hi Thanks for the quick responses. 2 bars on RID when idiot gas light would intermittently flash yellow. 7 bars after non - ethanol fill up.? Rear brake pulses when used singely. Evening adventurer2112 Unless the rear brake rotor was damaged during a tire change the typical cause of rear brake pulsation is due to rotor staining. That rotor staining is usually caused from the motorcycle sitting without moving for an extended time in a moist environment (or parked for a time with damp brake pads after washing the motorcycle). The brake pads cause an almost invisible oxidation or staining on the rotor surface that causes a braking friction increase in that stained area as the brake pads cross that area of the rotor. Rotor staining can sometimes be a pain to remove (depending on how bad it is & how deep the oxidation). Try vigorously cleaning the rotor using a red Scotch pad & brake clean. You usually need to really scrub at it to reduce the higher friction area. In some cases it takes using wet/dry sand paper & really working at it. I have seen staining so bad that I have had to remove the rotor & give it a very light bead blasting using well worn very fine glass beads at a low air pressure. Problem with some staining is you can't always see it & can't measure it as it is just a friction increase in one (brake pad) sized area. On your fuel gauge/light, the place to start is to clean the terminal pins on the fuel pump pass through where the fuel pump pigtail plugs into the main chassis harness. The fuel pump & fuel gauge/low fuel light share a common ground & that has been an issue on some older 1100/1150 motorcycles. Link to comment
adventurer2112 Posted September 13, 2021 Author Share Posted September 13, 2021 Thanks. I’m going to get the panels off during the week, so I can clean the wiring with Deoxit. Have to figure out the rotors. I thought maybe it was worn out @ 84 k miles. Jacj Link to comment
dirtrider Posted September 13, 2021 Share Posted September 13, 2021 10 hours ago, adventurer2112 said: Thanks. I’m going to get the panels off during the week, so I can clean the wiring with Deoxit. Have to figure out the rotors. I thought maybe it was worn out @ 84 k miles. Jacj Morning adventurer2112 The rotor might very well be worn thin but that isn't the cause of your brake pulsation. Link to comment
adventurer2112 Posted September 14, 2021 Author Share Posted September 14, 2021 Hi Ok. Thanks. J Link to comment
