adventurer2112 Posted September 12, 2021 Share Posted September 12, 2021 Hi Just bought 97 R1100RT 84 K miles. + PO installed Ohlins, SS brake lines, Twin Max synched throttle bodies, new tires. - Front engine cover melted a little bit. PO put 8 15 amp fuses in box. Put correct fuse amps in. Front brake sticks, I have to move brake lever forward to unstick front brake. Would a front brake rebuild fix this or so I need to buy the $400 front brake from Beemer boneyard. Or is there something else that might work ? im going to change all fluids. Bought an alternator pulley belt, spark plugs, spark plug wires, HE s, quick fuel disconnects. Fuel / submersible fuel hoses, ,air, oil filters.front engine cover. Installed a good RID., but broke dash board. Plasti welded, good for now. Any other recommendations? Jack Link to comment
Doctare Posted September 12, 2021 Share Posted September 12, 2021 I found brake seal kits here cheap. https://www.accu-products.com/110436292-seal-kit.html Link to comment
adventurer2112 Posted September 12, 2021 Author Share Posted September 12, 2021 Thanks. Rear brake pulses when stopping. I will check pads, but thinking it’s rotor. Jack 1 Link to comment
