John Ranalletta Posted September 10, 2021 Share Posted September 10, 2021 Needed a rattle clamp for towing. Thought about getting the welder out, buying a piece of 1/4" scrap plate, a couple of 1/2" bolts, nuts, washers, etc. Really? When I can get a pre-bent, power-coated unit complete from China in less than 24hrs for 8 bucks. Link to comment
Skywagon Posted September 10, 2021 Share Posted September 10, 2021 John...what do you use that for. I don't have one so I must need one...if I only knew what it was for I might get 2 Link to comment
Hosstage Posted September 10, 2021 Share Posted September 10, 2021 26 minutes ago, Skywagon said: John...what do you use that for. I don't have one so I must need one...if I only knew what it was for I might get 2 That's twice now you've posted to get stuff you didn't know about and don't need, but now have to have it, I'm starting to think you may have a problem... As far as the manufacturing, we've done it to ourselves, companies can outsource to make more money on a product, regulations and taxes have taken away many incentives and ability to manufacture. Also, companies are driven by profit more than quality product oftentimes, have to answer to shareholders, not business partners. Link to comment
John Ranalletta Posted September 10, 2021 Author Share Posted September 10, 2021 1 hour ago, Skywagon said: John...what do you use that for. I don't have one so I must need one...if I only knew what it was for I might get 2 When the hitch is in the receiver, there’s a little play; otherwise it would be tough to get in. On bumps and concrete joints, they rattle. A rattle clamp makes the hitch fast to the receiver preventing rattling. I just don’t like noises when pulling a trailer. Link to comment
Skywagon Posted September 10, 2021 Share Posted September 10, 2021 Thanks John. I definitely need one of those. Never heard of it. I’m super sensitive to sound when towing the boat Link to comment
John Ranalletta Posted September 10, 2021 Author Share Posted September 10, 2021 23 minutes ago, Skywagon said: Thanks John. I definitely need one of those. Never heard of it. I’m super sensitive to sound when towing the boat I’ll sell mine $12 plus s/h. Link to comment
MikeB60 Posted September 10, 2021 Share Posted September 10, 2021 These things are great. I have a aluminum trailer that causes the hitch to rattle with a light load. This clamp was the cure! Link to comment
Hosstage Posted September 10, 2021 Share Posted September 10, 2021 They're called beam clamps in the construction industry, $4. They're called anti rattle clamps in the motorcycle industry, $8. https://www.zoro.com/zoro-select-beam-clamp-in-electro-galvanized-steel-22fp82/i/G8551347/?utm_source=google&utm_medium=surfaces&utm_campaign=shopping feed&utm_content=free google shopping clicks&gclid=CjwKCAjwhOyJBhA4EiwAEcJdcXeoQT8WPT_9EdV6Nw66PxgKOIiVzXLrR139QXWN7uADOHXUURRTsxoCWWEQAvD_BwE Link to comment
Skywagon Posted September 10, 2021 Share Posted September 10, 2021 Kind of like the zoro ones Hosstage posted as they are galvanized. Mine will see lots of salt air and some salt water. Link to comment
Hosstage Posted September 10, 2021 Share Posted September 10, 2021 They are available at Home Depot more than likely. We get them from our construction supply vendors. 1 Link to comment
Hosstage Posted September 10, 2021 Share Posted September 10, 2021 Here's a picture of how it is used to attach strut to ceiling beams. Same concept on the trailer hitch. https://www.unistrutohio.com/unistrut-p2785-beam-clamp-1-58-channel?gclid=CjwKCAjwhOyJBhA4EiwAEcJdcQg3QxnuXW5p3Wz6O6NjOrv4-WZVaNRg9senGgJcI0gaRd8nP50ceRoCu74QAvD_BwE Link to comment
Skywagon Posted September 10, 2021 Share Posted September 10, 2021 Thanks Hosstage...I'll pick one up tomorrow from Home Depot. The one by my house shows they have 48 in stock. I'll coat them with Zinc Chromate and they should be ok for a while. Less than $5 to stop that rattle will be money well spent. Thanks John for the posting. Link to comment
John Ranalletta Posted September 12, 2021 Author Share Posted September 12, 2021 On 9/10/2021 at 7:11 PM, Skywagon said: Thanks Hosstage...I'll pick one up tomorrow from Home Depot. The one by my house shows they have 48 in stock. I'll coat them with Zinc Chromate and they should be ok for a while. Less than $5 to stop that rattle will be money well spent. Thanks John for the posting. Happy to be of help. Helpful to have a cheap box end ratchet. I have one and keep it in the tow vehicle boot. Link to comment
