Ron-M Posted September 8, 2021 Share Posted September 8, 2021 The Nav VI that I bought with my 2020 1250RT starting doing weird things so I called Garmin and they replaced it. The problem I am having with the new Nav VI is that it will not automatically switch from the "Where To - View Map" screen that appears upon starting the unit to the map view screen after a few minutes of driving as the old one did. I can't find how to activate this through the settings. Any suggestions? Thank you, Ron Link to comment
Bernie Posted September 8, 2021 Share Posted September 8, 2021 I had my Nav6 replaced 4 or 5 times and I have never had that problem. Maybe try to a factory reset and do another Garmin Express update. Link to comment
wbw6cos Posted September 8, 2021 Share Posted September 8, 2021 Hi Ron, at what outside temp did this occur? Mine started acting up at START while on a ride and I think I remember it being a little chilly outside. Link to comment
Ron-M Posted September 9, 2021 Author Share Posted September 9, 2021 Thanks Bernie, I will try the reset. William. Not chilly. It started about two months ago, slowly. On a ride one day, the screens kept changing on me, but then it corrected itself. For a few weeks anyway. Then all of a sudden, for no reason, after a stop on a ride the screen zeroed in on a close up of a POI that I had never been to. It would then ask me to "go to" this POI. When I would push "Go," the screen would come back to life for a quick minute then start the whole process all over again. At times it would freeze as well. No questions from Garmin. Replaced the device with no questions asked. But now I have to manually push the "View Map" to go to the map instead of it doing it automatically. Link to comment
wbw6cos Posted September 9, 2021 Share Posted September 9, 2021 Roger that. Mine did a similar malfunction. I read somewhere that some common situations involved cold weather. Not all, but enough to make me wonder. I kept playing with it to try and get it to reboot, but no luck while riding. At the first stop, I pulled it off the bike to manually power it down using the button on the rear. Suffice it to say, I have not seen the issue again, but my intermittent use is not a good measure of the fix. I have been reading about other people's problems, hoping I will not have to go through it. Hope it gets sorted for you. Link to comment
Bernie Posted September 10, 2021 Share Posted September 10, 2021 13 hours ago, Ron-M said: Thanks Bernie, I will try the reset. William. Not chilly. It started about two months ago, slowly. On a ride one day, the screens kept changing on me, but then it corrected itself. For a few weeks anyway. Then all of a sudden, for no reason, after a stop on a ride the screen zeroed in on a close up of a POI that I had never been to. It would then ask me to "go to" this POI. When I would push "Go," the screen would come back to life for a quick minute then start the whole process all over again. At times it would freeze as well. No questions from Garmin. Replaced the device with no questions asked. But now I have to manually push the "View Map" to go to the map instead of it doing it automatically. Good evening Ron, one thing I forgot to ask or mention. The next time you turn on the bike with the Nav6, make sure that there is a motorcycle displayed on the center of the top edge. If not push the symbol ( most likely a Car) and select Motorcycle. Maybe for some reason your new Nav6 doesn't recognize that it is inside a motorcycle cradle. Could also be dirty contacts on either the GPS or the cradle. 1 Link to comment
Ron-M Posted September 10, 2021 Author Share Posted September 10, 2021 Thanks Bernie. I will check that out. 1 Link to comment
