Kannon Posted August 30, 2021 Share Posted August 30, 2021 I'm going to be doing a wheel swap on a '20 GS with cross spoke wheels. Can someone tell me what the torque spec is for the front brake rotors. Also, is there anything tricky about swapping tire pressure sensors, This will be a swap for like wheels, my black wheels for another guys gold wheels. Thanks Link to comment
Rougarou Posted August 30, 2021 Share Posted August 30, 2021 My calibrated right arm says decently tight for the torque specs Which should equate to 'bout 38Nm/28ftlbs As for the sensors, take 'em off, put 'em on like you found them. Link to comment
duckbubbles Posted August 31, 2021 Share Posted August 31, 2021 I came up with 19nm. I'd use some blue/purple loctite, also. Frank Link to comment
Rougarou Posted August 31, 2021 Share Posted August 31, 2021 5 minutes ago, duckbubbles said: I came up with 19nm. I'd use some blue/purple loctite, also. Frank My bad, I's mis-read and put the caliper specs Link to comment
