Bob_1978 Posted August 21, 2021 Share Posted August 21, 2021 Here's what I'm looking for: - a simple horn upgrade that is louder than the "meep meep" from my 2013 RT - I don't need to sound like a semi truck or a locomotive - I would settle for a car-like horn similar to what my 2004RT put out - a single unit that is simple to install and won't require 3 hours / $300 in installation labor - a unit that won't tax the canbus / electrical system - quality build I'll spend up to $100 for something that will last. Any advice is appreciated! Link to comment
texRT2 Posted August 21, 2021 Share Posted August 21, 2021 Worked well for me. BMW auto horn 997 635 205 04. It has a snout but that is easily worked around. Uses same elect plug too. Deer and buzzards have all been warned by this horn....so far! Can be had for < 30.00 Link to comment
TEDZ Posted August 21, 2021 Share Posted August 21, 2021 I bought the Denali Sound Bomb Mini and the jumper harness they sell for the R1200RT. Fits like the original and the jumper eliminates cutting any wires. The prices is very reasonable. Link to comment
Selden Posted August 21, 2021 Share Posted August 21, 2021 1 hour ago, texRT2 said: Worked well for me. BMW auto horn 997 635 205 04. It has a snout but that is easily worked around. Uses same elect plug too. Deer and buzzards have all been warned by this horn....so far! Can be had for < 30.00 Thanks for the pointer. I've been looking for a replacement horn for my F700GS, and didn't want to mess around with connectors. This appears to be plug and play. That part number appears to come up on Amazon, labeled as a Porsche horn. https://www.amazon.com/997-635-205-04-2005-2013-Porsche-Note-Horn/dp/B00DJ6BORK/ Similarly, searching eBay for 996 635 205 04 returns a bunch of options, with prices all over the place. Link to comment
texRT2 Posted August 22, 2021 Share Posted August 22, 2021 1 hour ago, Selden said: Thanks for the pointer. I've been looking for a replacement horn for my F700GS, and didn't want to mess around with connectors. This appears to be plug and play. That part number appears to come up on Amazon, labeled as a Porsche horn. https://www.amazon.com/997-635-205-04-2005-2013-Porsche-Note-Horn/dp/B00DJ6BORK/ Similarly, searching eBay for 996 635 205 04 returns a bunch of options, with prices all over the place. Wasn't wearing glasses! Link to comment
Bob_1978 Posted August 23, 2021 Author Share Posted August 23, 2021 Thanks all for the advice. But I'm a bit confused and sorry if I'm dense - Selden, will the Porsche horn be plug and play with the 2013 RT? Appreciate confirmation before I buy it Link to comment
texRT2 Posted August 23, 2021 Share Posted August 23, 2021 OK...try this....BMW low tone horn 61338381271 which is also Clarton horn 997-635-205-04 Link to comment
JohnH Posted August 23, 2021 Share Posted August 23, 2021 Here's what the Hella horns I put on my 2012 RT sound like. Pictures show installation and BMW pigtail required https://www.bmwsporttouring.com/applications/core/interface/file/attachment.php?id=19980 Link to comment
Yango Posted August 30, 2021 Share Posted August 30, 2021 On 8/21/2021 at 3:57 PM, texRT2 said: Worked well for me. BMW auto horn 997 635 205 04. It has a snout but that is easily worked around. Uses same elect plug too. Deer and buzzards have all been warned by this horn....so far! Can be had for < 30.00 I’m considering this option, my BMW dealership has the car horn in stock. This is the part number I got from another thread: https://shop.bmw.ca/p/BMW__/Horn--low-pitch/43818293/61338381271.html Did you have to do any mods to install? And how much, if any, of the tupperware did you have to remove? Link to comment
texRT2 Posted August 31, 2021 Share Posted August 31, 2021 On 8/29/2021 at 11:21 PM, Yango said: I’m considering this option, my BMW dealership has the car horn in stock. This is the part number I got from another thread: https://shop.bmw.ca/p/BMW__/Horn--low-pitch/43818293/61338381271.html Did you have to do any mods to install? And how much, if any, of the tupperware did you have to remove? No body parts need be removed. Will have to fiddle with bracket as in a little persuasion (bending) because of the snorkle on the horn. Do not remember but it's possible I used the bracket off the stocker as it may be longer. Plugs right in for power 1 Link to comment
calldavid Posted August 31, 2021 Share Posted August 31, 2021 On 8/23/2021 at 8:13 AM, JohnH said: Here's what the Hella horns I put on my 2012 RT sound like. Pictures show installation and BMW pigtail required https://www.bmwsporttouring.com/applications/core/interface/file/attachment.php?id=19980 4.5 MB · 98 downloads Is this a universal horn from Hella. I don’t see listed as a replacement for a 1200RT. Although I could have missed Link to comment
JohnH Posted September 1, 2021 Share Posted September 1, 2021 Here’s the website for the Hella horns I bought from Summit Racing: https://www.summitracing.com/parts/hla-007424801 I used them without the relay and never had a problem. Link to comment
Rinkydink Posted September 2, 2021 Share Posted September 2, 2021 I have used the Clayton horn on my ‘17 RT and ‘21 900XR. Plug and play and loud!!!! Link to comment
calldavid Posted September 2, 2021 Share Posted September 2, 2021 3 hours ago, JohnH said: Here’s the website for the Hella horns I bought from Summit Racing: https://www.summitracing.com/parts/hla-007424801 I used them without the relay and never had a problem. Thank you. Link to comment
Bob_1978 Posted October 2, 2021 Author Share Posted October 2, 2021 Thanks to all for the advice. I ended up with the Clarton low tone horn for less than $30. Same wiring as OEM high tone horn so it was plug and play. MUCH louder! Google search: Clarton horn 997-635-205-04 Link to comment
