ButtUgly Posted May 19, 2006 Share Posted May 19, 2006 I recently sold my 1150GS to purchase a new 1200RT(On order / delivery next week!!!) I decided to keep my OpiMate trickle charge battery charger to use on my new bike. Reading some of the threads, I get the feeling that this will not be possible due to the Can Bus wiring technology on the RT. Can someone shed some light on this issue? thanx, Patrick Link to comment
drodg Posted May 19, 2006 Share Posted May 19, 2006 If I am not mistaken you have to hook up directly to the battery and not through the accessory plug. My Battery Tender I hooked up directly through the winter on my R12RT. Link to comment
steveknapp Posted May 19, 2006 Share Posted May 19, 2006 If I am not mistaken you have to hook up directly to the battery and not through the accessory plug. Correct. Link to comment
johnlt Posted May 19, 2006 Share Posted May 19, 2006 Another alternative is to install the rear accessory socket directly to the battery instead of into the bike wiring system. Many of us have done that and it works well plus gives you a good direct to battery source for high current accessories like a pump that can be a problem when used through the bike wiring. Link to comment
ButtUgly Posted May 19, 2006 Author Share Posted May 19, 2006 Excellent feedback. Thank you, gentlemen. I will rewire as soon as I get the bike! Cheers, Pat Link to comment
Redbrick Posted May 20, 2006 Share Posted May 20, 2006 I did the direct to battery hook-up...Just pull the seat and plug in........No problem and simple...Unless you are going to use the added rear BMW plug for a passenger or other use this is the best and simplest solution to trickle charging......... Phil........Redbrick Link to comment
Hiawatha Posted May 20, 2006 Share Posted May 20, 2006 I have my battery charger with a Gerbing's plug so I can use my direct wired Gerbing outlet for the charger hookup also. R1200ST Link to comment
