hellmutt Posted May 19, 2006 Share Posted May 19, 2006 My wiring diagram shows a Yellow, White and Brown wire to the headlight.........I believe that the brown is ground, however I need to know which of the remaining wires is the high beam so I can hook up a "Flash to Pass" garage door opener. I would like to do this in the morning so I can leave on a ten day ride. I do not need the door opener for the ride, however I have the side panel off at the moment to install a new battery and this would be a good time. Also, is the connection to the headlamp just a slip on connection that I can just pull off without actually removing the bulb. Link to comment
Ken H. Posted May 19, 2006 Share Posted May 19, 2006 White is high beam. BTW I have the Flash2Pass opener on our GS, it's the cat's meow! Link to comment
Mulepick Posted May 19, 2006 Share Posted May 19, 2006 No bulb removal, just pull the rubber 3-prong plug out from the back. Link to comment
