hmeiseles Posted May 18, 2006 Share Posted May 18, 2006 So Today I replace the BMW battery in my 03 K1200RS with an Odyssey PC680. It fits nicely. On my old r1100rt when you replaced the battery you had to reinitalize the computer and the fuel injection. Do I have to reinitalize the K1200RS and if I do what is the process? Thanks Link to comment
bmwmick Posted May 18, 2006 Share Posted May 18, 2006 Disconnect battery, connect battery, ignition on, engine off open and close the throttle 3 times slowly. Ignition off. Start engine normally. HTH, Mick Link to comment
hANNAbONE Posted May 19, 2006 Share Posted May 19, 2006 i hAVE yet to replace my battery but I asked my tech about the Odyssey dry cell technology and he stated that at least on my "K" bike - that I should stick with the BMW OEM battery. He reasons were that many non-OEM battery's have a different level of volts or something - and they won't supply enough power due to the ABS etc. I trust him - hec, I was trying to convince him that the Odyssey was my top pick - but he quenched that wick immediately, and forcefully. Link to comment
hmeiseles Posted May 19, 2006 Author Share Posted May 19, 2006 I must be confused since in electical terms the all 12 volt batteries have the about the same voltage so I wonder what you tech was talking about? So far the battery works fine. Howard Link to comment
bmwmick Posted May 19, 2006 Share Posted May 19, 2006 i hAVE yet to replace my battery but I asked my tech about the Odyssey dry cell technology and he stated that at least on my "K" bike - that I should stick with the BMW OEM battery. He reasons were that many non-OEM battery's have a different level of volts or something - and they won't supply enough power due to the ABS etc. I trust him - hec, I was trying to convince him that the Odyssey was my top pick - but he quenched that wick immediately, and forcefully. Most of them don't understand elecricity. : )) I use the Panasonic AGM batteries in all three bikes. I replace them every 4 years and have only had ONE fail in service but that was after 6 years when I forgot to replace it on my normal schedule. The one for K-Bikes is the LC-X1220P 20AH vs 16 for the odyssey and 275 CCA vs 220 for the odyssey. $47 from Digikey.com with free shipping. Mick Link to comment
hANNAbONE Posted May 19, 2006 Share Posted May 19, 2006 i'LL hAVE tO beat on him next time I'm down to KC at Engle's...I'll find out why he said what he said.. Link to comment
RFW Posted May 19, 2006 Share Posted May 19, 2006 i hAVE yet to replace my battery but I asked my tech about the Odyssey dry cell technology and he stated that at least on my "K" bike - that I should stick with the BMW OEM battery. He reasons were that many non-OEM battery's have a different level of volts or something - and they won't supply enough power due to the ABS etc. I trust him - hec, I was trying to convince him that the Odyssey was my top pick - but he quenched that wick immediately, and forcefully. Most of them don't understand elecricity. : )) Exactly. He's talking through his hat. Bob. Link to comment
Paul Mihalka Posted May 19, 2006 Share Posted May 19, 2006 "Odyssey battery won't supply enough power due to ABS" - that, to say it printable, is bovine manure. The BMW R1100 oilheads are famous for having ABS faults at startup because of lack of cranking power. The well known fix is a Odyssey battery. Link to comment
rdfrantz Posted May 25, 2006 Share Posted May 25, 2006 bONE, Mick is spot on. I found the Panasonic batteries, and Laney found them on Digikey (the best possible price anywhere)... Heck, way back in '02. Seriously, we've been using them successfully, and long lived for several years. I still don't think there's anything better, even at the higher prices. And that's really for folks who are in fact OEMing the Panasonic unit. See you down the road, brother. Link to comment
ELP_JC Posted September 6, 2006 Share Posted September 6, 2006 Hey guys, question here, as I was about to pay over $100 for an OEM gel unit to replace the 'wet' battery on my '03. Is it the same size as stock? For some reason, that Panasonic looks taller than stock on the photo, and might be a problem if I want to carry the took kit (which I do). And it's a drop-in replacement from stock (no drilling, no adapters, etc) from what I read, right? It shows '0' available at Digikey, by the way. Have to find out what's the lead time. Thanks for your help. Link to comment
bmwmick Posted September 6, 2006 Share Posted September 6, 2006 JC, Stay away from the GEL. Mick Link to comment
ELP_JC Posted September 6, 2006 Share Posted September 6, 2006 JC, stay away from the GEL. Mick Hey Mick, are they still problematic? Thought the problems when they came out were over. So the Panasonic then, huh? Link to comment
RFW Posted September 6, 2006 Share Posted September 6, 2006 i hAVE yet to replace my battery but I asked my tech about the Odyssey dry cell technology and he stated that at least on my "K" bike - that I should stick with the BMW OEM battery. He reasons were that many non-OEM battery's have a different level of volts or something - and they won't supply enough power due to the ABS etc. I trust him - hec, I was trying to convince him that the Odyssey was my top pick - but he quenched that wick immediately, and forcefully. He's wrong. Odysseys work very well indeed. Besides, they are NOT "dry cells". They are "AGM" batteries (AKA "valve regulated"). They are very wet indeed inside; each cell is just sealed by a pressure relief valve. An AGM battery requires a little higher voltage for a final charge, but all this means is that the battery will reach (perhaps) the 95% charge level instead of 100%. So what! Because of the use of basically pure lead plates (instead of lead alloyed with antimony or calcium for stiffness), the Odyssey has lower resistance, and therefore higher cranking power than a "normal" lead acid battery. Link to comment
bmwmick Posted September 6, 2006 Share Posted September 6, 2006 JC, stay away from the GEL. Mick Hey Mick, are they still problematic? Thought the problems when they came out were over. So the Panasonic then, huh? Yes, The GEL is still a poor choice for a battery on a motorcycle. Mick Link to comment
ELP_JC Posted September 7, 2006 Share Posted September 7, 2006 Thanks for the heads up gentlemen; will stay away from the gel then. Called Digikey, and they won't have our battery until October (darn!). Since I have a weeklong trip to CO on Sep 24, and would like to have a new battery, I'll probably have to get it from another place... at TWICE the price (geez). But still cheaper than a BMW gel. Thanks for your help again. Link to comment
bmwmick Posted September 7, 2006 Share Posted September 7, 2006 JC, Here is an alternate source for the Panasonic LC-X1220P. http://www.batteriesasap.com/111.html If you feel like paying twice that to get it local, do so. I'm sure that is worth something. DigiKey is still out of stock till. Mick Link to comment
ELP_JC Posted September 8, 2006 Share Posted September 8, 2006 Hey Mick, thanks a lot for the recommendation buddy, but they were one of the many vendors I already tried. And yes, like most, they also showed the battery 'in stock', when indeed it wasn't. I tried every vendor who popped up on Google, even if the price was twice as much ($85 is still a good deal compared to OEM), but nobody had one. I guess I'll take my chances with the OEM; still working perfectly after 4 years, but didn't want to risk failure for $80. At least I tried . Thanks again. Link to comment
SK_in_AB Posted October 10, 2006 Share Posted October 10, 2006 Thanks to this post, I sourced a new Panasonic battery for my '02 RT. I ordered it from DigiKey, as they claimed to handle all the US --> Canada details for the delivery. Wow - what great service. I ordered the battery at 3pm on Thursday. It was at my house when I got back from work on Friday at 5pm! They shipped with purolater, and covered the Canadian customs clearance which can often hold things up. All this and a price of $68 Canadian with the GST. Anyone out there looking for a new battery I highly recomend this source. Link to comment
ELP_JC Posted October 10, 2006 Share Posted October 10, 2006 Great news Stephen. Remember to fully charge it before using it; that extends its life considerably. I'm supposed to get mine today . Nobody had a Panasonic available before my CO tour, and really wanted that one, so took my chances with the stock battery, and fortunately, no issues. Digikey just got a shipment of 300+ batteries last week, so ordered mine on Thursday: $60 delivered. A bargain, if you ask me. Hope no alterations are necessary, but worst care scenario is enlarging holes; no biggie. Take care. Link to comment
Carnadero Posted October 10, 2006 Share Posted October 10, 2006 Digikey just got a shipment of 300+ batteries last week, so ordered mine on Thursday: Well that sux. Since Digikey had been out of stock on them for a while, I ended up springing for a Yuasa, as I couldn't wait any longer (cranking was starting to seem labored on cold mornings). Oh well, maybe in another four years... Link to comment
