mickeym3 Posted July 28, 2021 Share Posted July 28, 2021 Anyone seen such…a bit hesitant (gulp) to dealer hourly rates. Thanks Link to comment
dirtrider Posted July 29, 2021 Share Posted July 29, 2021 13 hours ago, mickeym3 said: Anyone seen such…a bit hesitant (gulp) to dealer hourly rates. Thanks I have only done one valve CHECK, I got lucky & they didn't need an adjustment so I didn't have to remove the camshafts. I sent you some info on the service procedure. It isn't a walkthrough but gives you most of the info that you need. (check your messages on this site) Not for the faint of heart_ but if the person doing the job has a pretty good handle on modern chain driven overhead cam engine mechanics it is doable at home. 1 Link to comment
mickeym3 Posted July 29, 2021 Author Share Posted July 29, 2021 Thanks dirtrider, you never fail to help those in need. Embarrassing that I frequent that forum and had failed to find it. $700 quote from dealer might indicate they may go over the book allowance if they have to replace shims. I’ve got ~1,000 miles to get everything laid out. Thanks again Link to comment
