Redman Posted June 7, 2021 Share Posted June 7, 2021 Not seeing how to loosen whatever so can rotate the controls to have brake lever and clutch lever at a better heigth. Link to comment
Redman Posted June 7, 2021 Author Share Posted June 7, 2021 Have taken out the bolt #8. cant get anything to move. Link to comment
Redman Posted June 7, 2021 Author Share Posted June 7, 2021 couldnt find anything here Link to comment
dirtrider Posted June 7, 2021 Share Posted June 7, 2021 9 hours ago, Redman said: Nor here. Morning Redman Have you tried loosening the pinch bolt then try rotating it? I'm not sure how much movement is possible but worth a try. Link to comment
Redman Posted June 7, 2021 Author Share Posted June 7, 2021 2 hours ago, dirtrider said: Morning Redman Have you tried loosening the pinch bolt then try rotating it? I'm not sure how much movement is possible but worth a try. Oh, I didnt see any bolt in that area. Will look again. Link to comment
bmwnomad Posted June 7, 2021 Share Posted June 7, 2021 You will have to remove the bottom cover (part 14) that's held on by the screws (15 and 16). Remove the switch pod, it should just lift off, but there might be another screw, can't remember. That will expose the pinch bolt. Link to comment
Redman Posted June 7, 2021 Author Share Posted June 7, 2021 1 hour ago, bmwnomad said: You will have to remove the bottom cover (part 14) that's held on by the screws (15 and 16). Remove the switch pod, it should just lift off, but there might be another screw, can't remember. That will expose the pinch bolt. I was starting to suspect that. And I gather that applies to the brake and the clutch. Link to comment
Redman Posted June 7, 2021 Author Share Posted June 7, 2021 7 hours ago, dirtrider said: . . . . . . . . Am wondering if our new discovery of this bike having the "lowering" option (x0499 = low suspension & extra low seat) might have some effect on this clutch-brake lever situation. Link to comment
dirtrider Posted June 7, 2021 Share Posted June 7, 2021 1 hour ago, Redman said: Am wondering if our new discovery of this bike having the "lowering" option (x0499 = low suspension & extra low seat) might have some effect on this clutch-brake lever situation. Afternoon Redman It very well could (well the extra low seat part anyhow), I still have an 09 hexhead with standard height seat & have no complaints on the control lever placement. You might try a folded blanket or (something) placed on the seat to raise your butt up a little to see if that helps your lever position feel. Link to comment
Redman Posted June 26, 2021 Author Share Posted June 26, 2021 On 6/7/2021 at 6:21 AM, dirtrider said: Morning Redman Have you tried loosening the pinch bolt then try rotating it? I'm not sure how much movement is possible but worth a try. On the clutch side: I did find two screws underneath so can remove a cover from underneath, and a screw from the face of the swiitch assembly that loosened up the swtich assembly, could wiggle the switch assembly just enough to somewhat see what might have been that pinch bolt. But could not see how to get the switch assembly away from the bar. Must be some tab somewhere to push to get it to release or something. But I was concerned about breaking something a couple days before a big trip, got nervous, and just put back together. So, now I need to figure out how to get the switch assembly to release. Link to comment
Redman Posted June 26, 2021 Author Share Posted June 26, 2021 On 6/7/2021 at 12:23 PM, bmwnomad said: You will have to remove the bottom cover (part 14) that's held on by the screws (15 and 16). Remove the switch pod, it should just lift off, but there might be another screw, can't remember. That will expose the pinch bolt. ////QUOTE Remove the switch pod..... ////EndQUOTE I got to that point, and could not see how to release it. Link to comment
dirtrider Posted June 26, 2021 Share Posted June 26, 2021 8 hours ago, Redman said: I got to that point, and could not see how to release it. Morning Redman Link to comment
Redman Posted July 13, 2021 Author Share Posted July 13, 2021 Thanks. Will get back to that. . Link to comment
