Mike Posted May 19, 2021 Share Posted May 19, 2021 I get a little nervous when I do this sort of thing (last time was six years ago), so bear with me. I’m going to attempt the installation of a PDM 60 on my new 2021 GSA and I started poking around last night. Everything is tightly packaged, inducing a tight feeling in my chest when I contemplate finding a wire for an ignition-switched circuit that can instruct my PDM60 to turn itself on and off. I’m going to mount it under the seat, or just off to the side. Still pondering the placement. Help, please…a reasonably accessible switched wire? Thanks! Link to comment
CruisinCruzan Posted May 19, 2021 Share Posted May 19, 2021 Use the power lead from the nearest power socket. Link to comment
Mike Posted May 19, 2021 Author Share Posted May 19, 2021 31 minutes ago, CruisinCruzan said: Use the power lead from the nearest power socket. Thanks…took me a bit of disassembly to figure out how to get to it. It seemed a bit alarming until I did it, but it required unclipping the bike’s brain and swinging it up out of the way to gain access to the wire. If the bike still runs I’ll deem it a success. Link to comment
dirtrider Posted May 19, 2021 Share Posted May 19, 2021 26 minutes ago, Mike said: Thanks…took me a bit of disassembly to figure out how to get to it. It seemed a bit alarming until I did it, but it required unclipping the bike’s brain and swinging it up out of the way to gain access to the wire. If the bike still runs I’ll deem it a success. Afternoon Mike Those accessory power sockets are computer controlled so so in some cases transformer type loads will trick them into either not shutting down thinking that the load is a connected battery charger, or the shutdown can act erratically. Other times it will function just fine. Before making anything too permanent make sure that the PDM60 shuts down every time & in a reasonable time period. If you do battery charge through the factory power ports using an approved charger then your PDM60 will probably not shut down during the entire charger connection time. Link to comment
Mike Posted May 19, 2021 Author Share Posted May 19, 2021 3 hours ago, dirtrider said: Afternoon Mike Those accessory power sockets are computer controlled so so in some cases transformer type loads will trick them into either not shutting down thinking that the load is a connected battery charger, or the shutdown can act erratically. Other times it will function just fine. Before making anything too permanent make sure that the PDM60 shuts down every time & in a reasonable time period. If you do battery charge through the factory power ports using an approved charger then your PDM60 will probably not shut down during the entire charger connection time. Thanks, DR. Installed. It seems to be operating properly. I’ll keep an eye on it. I use the CTEK charger, with a direct connection to the battery. Seems to work well, and is fairly reasonably priced. Link to comment
