ducati2 Posted May 2, 2021 Share Posted May 2, 2021 2015 r1200rt cruise works great , except according to the manual, tapping the clutch should disengage it...and it does not. Engine just revs to scary rpm. Anyone else experienced this? What could be a fix? Link to comment
Alfred02 Posted May 3, 2021 Share Posted May 3, 2021 There should be a microswitch at the clutch lever. Either it isn't working or the fiddly connector that plugs into the grip (under the grip) is not plugged in properly or the pins are bend. I had bend pins after the service guys replaced my cruise cruise control just weeks after owning it. Link to comment
ducati2 Posted May 3, 2021 Author Share Posted May 3, 2021 yep,,, found the plug to the microswitch apparently backed off.. will get it out tonight to check if that was it for certain.. Link to comment
